truck pulls to right
Old Mar 11, 2007 | 12:52 AM
built 80 f250's Avatar
built 80 f250
my truck pulls to the right when i let go of the steering wheel. i have checked to make sure that there is no play in the tie rods and the brakes dont drag, the tire pressure in both are the same. i have got no idea as to why it does this but one thing i have noticed is the truck tracks in a straight line when i am slowing down.
Old Mar 11, 2007 | 01:11 AM
phil6608's Avatar
phil6608
Whens the last time you had a front end alignment?
Old Mar 11, 2007 | 02:43 PM
built 80 f250
last week i had it done
Old Mar 11, 2007 | 05:09 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Are the tires worn? Once a tire starts a wear pattern, it's just about impossible to change it. That's why I'm asking. What about air pressure in the rear tires? It's possible the right rear brake could be dragging a little bit too.
Old Mar 11, 2007 | 10:08 PM
built 80 f250
tires are all newish as i got them in the summer and dont drive a lot the pressure is the same in the front an back. im not sure about the brake dragging or not i will check that tomorow
