valve seal info
Old Mar 10, 2007 | 09:07 PM
j tate's Avatar
j tate
valve seal info
today i started cleaning up the heads to go back on the motor. i purchased a topend gasket set, it came with everything but the intake gas, and the exhaust valve shields. so i went ahead and ordered both. i started breaking down the valve springs to change valve seals. i noticed on the heads that they didnt have the exhaust valve shields. what i mean by the exhaust valve shields, its not the ones that snap into the bottom of the valve spring retainer, its the ones that just sit over the valve guides. there just a white umbrella shaped piece of either plastic or teflon. my question is i went ahead and installed them on the exhaust guides, has anybody else used them or if the heads didnt come with them should i have just left them out?
Old Mar 10, 2007 | 09:30 PM
Spectramac's Avatar
Spectramac
I hope you didn't replace them thinking you would cure your engine of oil burning. They do very little for smoke (other than cold startup). I'm sure the valves are a little loose by now anyway and could use a little extra seal.
Old Mar 10, 2007 | 09:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I put them in my engine when I did the rebuild.
Intake and exhaust seals were in my top end gasket set from Fel-Pro.
Old Mar 10, 2007 | 09:44 PM
j tate's Avatar
j tate
no didnt think it would cure everything just didnt know if i should have used them because it didnt have them to begin with, i bought them so i used them. i know every gasser that ive ever rebuilt had those shields on the exhaust guides didnt know if a diesel had them. i tell you i was pretty impressed, for as many miles as this engine has on it (263,000) it is still pretty tight. the only issue i seen i had is someone had mixed two bb injectors with six factory injectors. not to sure if this is an issue are not.
Old Mar 10, 2007 | 09:49 PM
Spectramac's Avatar
Spectramac
Some people would argue this point to death, but you'd never tell the difference with old injectors anyway. Any evidence of lean burning on those two pistons?
Old Mar 10, 2007 | 10:03 PM
j tate's Avatar
j tate
cant remember which ones it was but when i took them out the engine three of them were sopping wet on the tips, and all the rest were dry. i figured that was my bad ones. im going to test all of them before i put them back in the engine, ive just about have my homemade tester built. but will probley just put a new set in anyway.
Old Mar 10, 2007 | 10:11 PM
Spectramac's Avatar
Spectramac
Yeah, they were probably leaking. A new set would be nice if you have the funds to do it. Gives them a nice crisp even rattle.
Old Mar 11, 2007 | 05:19 PM
j tate's Avatar
j tate
dont really have the funds, but are going to use the funds anyway. lol got too look around and make sure my wife aint looking lol lol. nah just kidding she dont care because as soon as i make it my dd she gets the new truck back. so do you think it would be alright if i tested the injectors and just replaced the ones thats bad?
Old Mar 11, 2007 | 07:17 PM
Spectramac's Avatar
Spectramac
Yeah, as long as they pop around the same time (around 1600 lbs if I remember right), look ok on the tips and don't drip I'd run 'em again. Put the new ones in the back somewhere so the older ones are easy to get at later.
