Hitch Cross-Compatibilty
Old Mar 10, 2007 | 07:50 PM
Americanmadeford's Avatar
Americanmadeford
Alright, simple question. Will a hitch bolted to a 77 F150 bolt up to an 85 f150?
Thanks
Old Mar 10, 2007 | 08:40 PM
westtntrucker's Avatar
westtntrucker
According to Hidden hitch, the part numbers are the same. If you transfer the hitch, get new grade 8 bolts.
Old Mar 13, 2007 | 09:53 AM
Americanmadeford
Thank you very much!
Old Mar 25, 2007 | 05:36 PM
Americanmadeford
Alright, I cant install the hitch. It doesnt clear the aftermarket bumper on this truck.
Next question... According to a label on this bumper It can handle a 7500 pound trailer with a 750 pound tounge weight. Can this really be done?
Can I still, say, pull a dual axle enclosed Uhaul trialer loaded w/ furniture with my bumper?
Old Mar 25, 2007 | 05:58 PM
CougarXR02's Avatar
CougarXR02
I have seen bumbers like that, and when installed on the proper truck, and installed properly, they can tow that kind of weight. However, you never know if it was put on in someone's backyard, or was bought at a swap meet, and if the fasteners used are up to the task. Take a real good look at where the mounts are, and that the bolts holding it have the grade 5 or better markings on them. It may be a better idea if you already have the receiver hitch, to go find a clean used stock bumper and go with your receiver hitch.
Old Mar 25, 2007 | 06:14 PM
Americanmadeford
Heh, that was my next question. It looks like my truck has some frame damage, and the bumper was sort-of rigger-nigged on. Here are a few pictures.
Old Mar 25, 2007 | 06:45 PM
Greywolf's Avatar
Greywolf
Break out an oxy-acetylene, carve that piece of crud for a class two or whatever, and get beyond it.
You need a reciever hitch. Making do for the time being is always a bad idea.
Don't wait for me to say: "I TOLJA..."
Look at it this way - you can half rip your bumper off (very expensively) or do it right ONCE, and ONCE ONLY...
Please choose wisely.
"When the tail wags the dog - it is invariably painful"
I can tell you this much... Whoever installed that bumper ripped up a lot of metal. IT'S JUNK.
Wherever the metal is torn, especially next to that one bolt, it will continue to rip.
Old Mar 25, 2007 | 06:55 PM
ericsmith32's Avatar
ericsmith32
Uhaul won't rent trailers unless you have a hitch.
Old Mar 25, 2007 | 06:58 PM
Greywolf's Avatar
Greywolf
Yeah they will. But U-Haul hitches are garbage.
They will install one for a fee...
Old Mar 25, 2007 | 07:07 PM
Americanmadeford
Alright, thanks for the replies thus far.
How does a stock bumper mate up with the frame? In other words, how hard will it be to put an OE bumper back on?
Old Mar 25, 2007 | 07:26 PM
Greywolf's Avatar
Greywolf
BOLT IT UP -provided the jackasses that put that one on didn't ruin your frame.
Not knowing if the original holes and threads were rusted in the time being - I would also get a tap and die set to chase the threads in the original bolt holes too. Use tranny fluid to lube the tap if you have to do that.
Old Mar 25, 2007 | 07:39 PM
jroehl's Avatar
jroehl
I couldn't tell from the pics, but the stock bumper probably has a couple supports that run at an angle from the frame to near the ends of the inside of the bumper. You may need to replace those.
Jason
Old Mar 26, 2007 | 10:13 PM
Greywolf's Avatar
Greywolf
Wire feed welding cures many sins.
That thing needs a reciever hitch - even if the bumper has to be cut out to do it right.
Half-way measures only work until you reach the approximate middle.
It is better to have it and not need it - than to need it and not have it.
Old Mar 27, 2007 | 08:02 PM
Americanmadeford
Alright, I took the bumper off. The supports are still in place and look pretty good to me.
I was told the hitch receiver, bolts inside the frame, but I dont see that happening. Does it instead, bolt underneath the frame?
Old Mar 27, 2007 | 10:52 PM
Greywolf's Avatar
Greywolf
You may have to drill some holes for bolts. Sometimes they are both bolted AND welded.
Next question is: Do the supports for the reciever fit snugly inside the frame rails?
If they do, it's time to break out a large drill bit and maybe a half inch drill.
I'll also tell ya this - once you have your holes drilled, and made sure it all fits, clean every bit of rust out of there and coat it with a serious rust preventer and or apply PURE silicone around the area where the two will come together.
RUST is the DEVIL at work!!!
