Offy DP cleaning
Old Mar 9, 2007 | 03:55 PM
Ranger GT2's Avatar
Ranger GT2
Offy DP cleaning
Has anyone tried to clean the inside of a Offy DP intake? What did you use and how well did it work? I have access to a glass bead cabnet to clean the outside but didn't figure it would work well on the inside.
Old Mar 10, 2007 | 03:40 AM
Col Flashman's Avatar
Col Flashman
Probably be easier just to Hot Tank it.
Old Mar 11, 2007 | 07:55 PM
stewbronco's Avatar
stewbronco
NEVER HOT TANK aluminum!!! It will be "eaten alive"Find a aircraft engine reman facility ...they will have a "Hot parts washer" for aluminum.Then bead blast.
Old Mar 11, 2007 | 09:30 PM
Col Flashman
That's what I meant to write, Hot Parts Washer, Core Melt Down, Core Melt Down.
Old Mar 12, 2007 | 11:24 AM
Motorhead351's Avatar
Motorhead351
You might try soaking it in "Castrol super clean"
I cleaned an intake once with it, Id use a small amount of product when you mix it with water, too much and as I recall the aluminum turns white but cleans up find after that with soapy water. Just follow the directions. One things for certain, the super clean works very well. I soaked a pair of used heads in it once, took little effort with a brush to remove the carbon build up in the exhaust ports and chamber, you wont have that much trouble with your intake. Its also biodegradeable.
Old Mar 12, 2007 | 02:33 PM
Ranger GT2's Avatar
Ranger GT2
Thanks, I'll try the super clean and see how it works
Old Mar 13, 2007 | 01:57 PM
Motorhead351
Let me know how that works for you.
Now that I think about it, it may have been another product that turned the intake white. As I used the super clean alot cleaning the engine bay, I do remember that much...haha...which included an aluminum intake.
