Stalling on acceleration
Old Mar 9, 2007 | 02:36 PM
ftrk66's Avatar
ftrk66
Dear Friends:
my I-6,300 Ford engine runs fine at idle and up to 50 MPH, when accelerating it starts hesitating then stalls or die, I had to release the gas pedal and press again to get the engine running again.
The only thing I did is removing the Exhaust Control Valve because it stucks in half close position, and heats up the exhaust manifold to a very hi temp (red colour).
Do you think that was the problem or do I have to check something else.
Wish to get a clue for that stalling.
Hamid.
Old Mar 9, 2007 | 03:18 PM
Silver Streak's Avatar
Silver Streak
Is it carb or EFI?
Old Mar 10, 2007 | 01:07 PM
ftrk66's Avatar
ftrk66
It is a carb.
The engine was running fine before I took both manifolds out and disassymbled them and remove the stuck exhaust control valve. The same thing for the carb I just removed it and put it back.
Old Mar 10, 2007 | 06:44 PM
Jikz's Avatar
Jikz
what is the condition of your carb? I just rebuilt mine today and got all the adjustments correct finally, and it is running like a champ. check your fuel mix, and float level. mine was running super rich and had several failing components and it would stall on accel as well. also had a nasty idle. now it is normal.
Old Mar 11, 2007 | 08:32 AM
ftrk66's Avatar
ftrk66
Jiks:
My carb is Carter 1 brl with electric choke, fits 86 year model engine. It was running fine, just got back from 1200 Mile trip. I just removed it like I said for ETV ( Exhaust Thermactor Valve) deactivation due to stuck in half close position. The Carb is new rebuilt installed 6 monthes ago. I am afraid I have to put a new ETV on. That manifold is pain in the butt, I removed it nearly 6 times for many reasons.
Thanks for your info.
Hamid
