clutch / trans problem...
my f150 is giving me problems again.
i have a manual 5gear trans and a 5l v8.
when engine is cold, i can put in gears without any problems.
when its in operation temp, gears wont slide in easily. i have to use force, sometimes i even have to gear through from 5th to 1st to get 1st and 2nd working.
also, when 1st is in, and i put the clutch and release a bit and engage full again, clutch seems to stay sliding and gears wont go out easily (and are not able to put in again, i have to do the procedure i described above)
but when i stirr the shifter leftrightleftright gear will go in again.
first i thought maybe the clutch cylinder (above, the "giver") may be defect. but it isnt, its building up pressure normally. also, the "taker" is not leaking. i have bleeded the system, all fine.
so whats my problem? any clue?
