I have a question. Last night the fiancee noticed a rumbling/low key humming noise when my truck was rolling. It seemed to be dependant on the speed and may have gotten a TINY bit worse when slowing down. I have heard it for a while, but just assumed it was the tires, but now that she noticed it, it got me thinking. How can I check to see if my unit bearings are going out?
Is there anywhere to get these things cheap?
I checked to make sure the front driveline was unlocked, because I had it in 4WD earlier that day moving a camper, but the front D/S did not turn when she drove it up and backwards.
Jack up the suspected side,move the tire at 3 & 9 and 12 & 6 for any movement.There should be none.If there is you can stick your head behind the tire to see the hub assymbly wiggling.
In my experience, the sound coming from a loose or failing front wheel bearing will change in intensity as you sway the truck from side to side.
Yeah, drive the truck on a smooth road with curves. As the truck goes into turns the sound should change noticably. Depending on which way you turn the sound will be worse or it may be less. I forget how to tell which wheel it is, but supposedly this should tell you.
It will be affected only by road speed, ie the pitch of the sound will rise with speed. It will not be affected much by applying the brakes except for the change is road speed I mentioned. It is not affected by tranny gear or engine speed, other than again what the road speed is from those.
I just got done with a wheel bearing problem on my car. Since it was under warranty I didn't go further than the above diagnosis method.
Didn't see what year or model you have, but doing the bearings on my 94 F250 4WD is not hard. Two gotchas are 1) You need to find the big C clip that holds the 4WD guts in. When it is greasy you won't see it but can feel it. 2) You need a big ****** impact wrench to break it loose and I think initial torque to seat the bearings is something like 250-400 ft#s.
Dude.... just jack it up like heidiandmax said.... and grab it at 3 and 9 and pull back and forth. You will know if the bearings are toast. The wheel will slide in and out. If you grab the wheel at the top and bottom and wiggle it around..if you have play it will be the ball joints. the bearings in these trucks are not serviceable...meaning not rebuildable. So you have to buy the whole hub/bearing unit. It is quite spendy... so check out the prices on www.powerstrokeshop.com It is not hard to do yourself...
