gauge lights, need help.
Old Mar 8, 2007 | 02:56 PM
DieselRunner's Avatar
DieselRunner
so ive had my truck for about 6 months(1991 f-250 7.3l) and the backgroud lights for my gauge's were never hooked up properly. There pyrometer and boost gauges, mounted on the a-pilar. I want to wire it up so they will turn on with my other instrament lights. the groud is hooked up but the positive was just stuck in a un-used slot on the fuse block, with no power. so now my question, where do i have to wire up the positive so that they will come on and off with the instrament lights?
thanks.
Old Mar 8, 2007 | 03:14 PM
ubereal2's Avatar
ubereal2
Smile
If you can remove the headlight switch. With a 12 volt test light, turn the switch on and off checking for power when you turn you're lights on. Tap into that wire and it will feed power to you're lights when you turn them on.
Bob
Old Mar 8, 2007 | 03:16 PM
DieselRunner
ohhh yeah i understand, thanks for the quick reply!
Old Mar 8, 2007 | 08:20 PM
Franklin2's Avatar
Franklin2
You can get under the dash and find any blue/red wire going to any of your dash lights and splice into that.
Old Mar 8, 2007 | 08:43 PM
DieselRunner
yeah i just took out the lights switch and ran it into one of the plugs, real easy, thanks.
