battery shut off
Old Mar 10, 2007 | 06:23 PM
gusso's Avatar
gusso
Thanks, SPL Tech, Then can I assume the voltage drop is normal for all solenoids? And therefore I should not have battery drain problem? Or will my vehicle
burn to the ground?
Old Mar 10, 2007 | 06:57 PM
mhg's Avatar
mhg
hey gusso lets start over
what is it you are trying to do
give us an idea and we can give better info
for staight forward elect. sys. control you need to control wires
that feed the cab not starter
to feed acc. then you need new wires from hot side of starter
solenoid to continuos duty sol. to the acc.
Old Mar 10, 2007 | 07:06 PM
SPL Tech's Avatar
SPL Tech
burn to the ground?
Well the voltage drop will very depending on what solenoid you have and how well you terminated your wires. But if you are not doing this in a voltage critical application, the voltage drop be enough to matter. If its just to cut power to your car, your engine will still start with additional voltage drop being that its not that much as long as you terminate the wire right. However like said above, what are you trying to do? And the voltage drop has nothing to do with a fire. The only way you will have to worry about a fire is if two unfused wire short out for a prolonged amount of time. And the voltage drop across the solenoid has nothing to do with battery drain.
Old Mar 10, 2007 | 07:22 PM
gusso's Avatar
gusso
Hi, mhg; I`m exploring the idea of putting a "latching" solenoid between
the starter and the starter solenoid, then hooking a hidden switch to it
to be used as an anti theft device. [ switching off the starter ] And thanks,
mgh, for suggesting we start over as it seems sometimes people that answer
posts don`t always read correctly the post they are responding to. Anyway ,thats what I`m exploring. By all means, mgh, give me your thoughts.
Old Mar 10, 2007 | 07:40 PM
Franklin2's Avatar
Franklin2
Hey, now we know what you want to do!
Is there a reason you want to kill all power with a large solenoid/relay?
A simple hidden switch interrupting the coil power will let the engine crank but not start.
Another simple switch that interrupts the red/blue wire going to the factory starting solenoid will not let it crank, but it could be roll started, unless you kill the coil too.
Old Mar 10, 2007 | 08:09 PM
gusso's Avatar
gusso
Hay, Dave, I never thought about the bad guys being able to push my truck
to start it. Great idea [to me] to switch the wire that goes the to coil. So now
thats what I`ll do. Any better ideas? Thanks much. Great info.
Old Mar 11, 2007 | 09:58 AM
mhg's Avatar
mhg
good info makes life easier
Old Mar 11, 2007 | 10:53 PM
gusso's Avatar
gusso
Thanks all. What a great forum!
Old Mar 12, 2007 | 12:02 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
A little on topic here; my friend called in a panic as he went shopping then his 70 PU wouldn't start just starter relay clicking.
Found the cable to the starter had 14 ohms resistance, nuff to screw things up, jumped direct to the starter terminal post and it cranked so he can get it home.
I clean then coat every cable and terminal point with Thomas & Betts conductive anti-corrosion compound.
With this compound every connection with Fluke 87 meter reads zero ohms, meter reads to 1/10 ohm.
