starting issues... agian
Old Mar 8, 2007 | 12:24 PM
Justjake71's Avatar
Justjake71
well she wont start again, i was out in some mud and i guess the power steering didnt like i start to drive off and the power steering goes out so i pull into wallmart get some fluid(the cap popped off of the resovior) filled it up tightened the belt (cause it slipped off) and drove it back fine. but when i stopped it backfired really loud. and now it wont start again 300 straight 6 and i rebuilt the carb, i guess maybe to look again, but if theres anyother ideas shoot em at me.
Old Mar 8, 2007 | 08:38 PM
Franklin2's Avatar
Franklin2
Will it crank?
If it will crank, take the aircleaner off and look down the carb while pushing back on the throttle. Do you see any fuel squirting?
Old Mar 8, 2007 | 11:40 PM
gearhead351's Avatar
gearhead351
You might have jumped the timing chain. When mine jumped it made that loud POP! and well its pretty obvious that it wont restart. Crank your motor over by hand to TDC and check to see if your rotor is pointing to cylinder #1.
Old Mar 16, 2007 | 01:29 PM
Justjake71's Avatar
Justjake71
the timing chain didnt jump and its getting fuel.
Old Mar 16, 2007 | 06:51 PM
Franklin2's Avatar
Franklin2
Are you getting spark?
By the way, the 300 six has timing gears, one of which is phenolic, which has been known to strip the teeth. If you want to make sure that's not it, turn the engine to top dead center and see if the rotor is pointing to the #1 sparkplug wire in the cap.
Old Mar 17, 2007 | 03:36 PM
Justjake71's Avatar
Justjake71
spark yes, and the rotor is on one at tdc
Old Mar 17, 2007 | 07:50 PM
Franklin2's Avatar
Franklin2
If you have spark, fuel, and the timing is correct, the only other thing I have had that would make an engine not start, is the plugs being fouled out with fuel. You may want to take them out and see if they are wet with fuel or really black and sooty. If they are, you may have to get a new set. I have tried to clean them before, but sometimes it doesn't help, and only new ones will make it go.
Old Mar 19, 2007 | 09:10 PM
Justjake71's Avatar
Justjake71
plugs are new
Old Mar 19, 2007 | 09:31 PM
power_speed's Avatar
power_speed
Sounds lIke you got a demon possed beast there.
Old Mar 19, 2007 | 11:49 PM
Justjake71's Avatar
Justjake71
Anyone got any holy water/gas?
Old Mar 20, 2007 | 05:38 PM
power_speed
Try Putting a Cross on It. With a little faith it will work.
Old Mar 23, 2007 | 12:37 AM
Justjake71's Avatar
Justjake71
new ideas anyone??
Old Mar 27, 2007 | 07:33 PM
Justjake71's Avatar
Justjake71
sorry to bug but any ideas?
Old Mar 27, 2007 | 08:17 PM
power_speed
Sorry jake I don't have any new Ideas. My rig has never had that problem.
Old Mar 27, 2007 | 08:37 PM
wildjon300ci's Avatar
wildjon300ci
Check the TFI module...also yank the dizzy and make sure the drive gear didn't strip it's pin.
