Fuel Pressure Port
Old Mar 8, 2007 | 09:14 AM
bradleyj's Avatar
bradleyj
Fuel Pressure Port
Can anyone tell me where I can install a fuel pressure sensor with a 1/8" NPT fitting? I don't see any threaded ports in the fuel system.
Old Mar 8, 2007 | 09:29 AM
nlemerise's Avatar
nlemerise
You can grab fuel pressure from the rear of the fuel filter bowl. On the back-side (the side facing the firewall) you'll find a plug with an allen head (if I remember correctly) that you can take out and put a fitting into. I believe, if I remember correctly, that it is an 1/8 NPT. That is where I tied in for an underhood fuel pressure gauge
http://h1.ripway.com/nlemerise/Ford/gaugeinstall.doc
I would not run the fuel pressure into the cab without using a sending unit - it could get ugly real quick!
Old Mar 8, 2007 | 05:07 PM
John311t's Avatar
John311t
The back of the fuel bowl, take out the allen plug. That is where you can tap in, but you will need an adapter if it is a electronic sender fuel pressure gauge. Any local hydraulic store will have it.
Old Mar 22, 2007 | 02:44 PM
bradleyj's Avatar
bradleyj
Yes, I took that plug out and saw that the thread size did not match up to the threads on the sender. Do you have any idea what size/pitch thread that is?
Old Mar 22, 2007 | 02:47 PM
John311t's Avatar
John311t
I honestly have no clue, i went to the hardware stores and rigged something up with brass fitting put it all together and it leaked, so i tighten it up and it broke the fittings. I found out it wasnt exactly the right size , so then i just went to the hydro store and showed them the plug and the sensor and they had one with a new o-ring on it.
Old Mar 22, 2007 | 03:13 PM
nlemerise's Avatar
nlemerise
Take the plug from the filter bowl and visit a hydraulic shop...they have the correct fitting and adapter you need.
Old Mar 22, 2007 | 03:19 PM
mrfixit64857's Avatar
mrfixit64857
Gosh... there was another thread about this a couple months ago with pictures and everything.... Gonna see if I can find it
Found it... but not the pix I was expecting. Here it is:https://www.ford-trucks.com/forums/5...l+plug+adapter
If you need more, you can IM some of those good men!
cps
Apr 5, 2013 03:24 PM
weldworks54
Sep 26, 2011 09:36 PM
jwheatley20
Feb 10, 2010 03:10 PM
House Husband
Aug 12, 2008 06:17 PM
Ford Truck Racer
May 13, 2006 08:39 AM
