Sponsored by: Real Truck
Pinion Bearing
Old Mar 8, 2007 | 07:01 AM
bc56845's Avatar
bc56845
Pinion Bearing
Well, less than a week after I got my new clutch in I find that my pinion bearing is toast. Started vibrating real bad yesterday. dropped the driveshaft and the pinion yoke had about a 1/4" of up and down movement in it. I got it torn down last night the outer bearing is real pitted and loose. The ring gear's got little chips out at the heel of the gear. I'm having trouble finding the inner bearing locally. The drivetrain place here cant have it until next week. Any tips or suggestions on picking up the ring and pinion? Anybody else had this problem?
Old Mar 8, 2007 | 07:21 AM
johnjk's Avatar
johnjk
What axle?
Check with this place and ask to speak to Alex if possible:
http://www.performanceoffroadcenter.com
He does a lot of gear work and usually has great prices and availability on parts.
He's in Athens, Ga, so he's not too far from you.
Old Mar 8, 2007 | 09:25 AM
bc56845's Avatar
bc56845
rear axle-sterling 10.5
Old Mar 13, 2007 | 06:23 AM
bc56845's Avatar
bc56845
Well, I put all new bearings in the rear end, set the gears back up right, pattern looked fine, backlash was .012" drove fine for 2 days then it went out again last night. So now I'm gonna look for a whole axle from the junk yard. I started looking this morning on car-part.com and it asks you for all of these tag codes. What are all of these different codes? shouldnt a single wheel truck have the same axle, just different ratios? Also, does anybody think a driveshaft problem would cause those pinion bearings to go out? Its got a new ujoint at the back.
3.73 ratio, tag S136B
3.73 ratio, tag S138B
3.73 ratio, tag S141B
4.10 ratio, tag S156B
4.10 ratio, tag S157B
4.30 ratio, tag S421B
3.73 ratio, tag S406B
3.73 ratio, tag S409B
3.73 ratio, tags S136C, S136E and S136F
3.73 ratio, tags S138C, S138E and S138F
3.73 ratio, tags S141C, S141E and S141F
4.10 ratio, tags S156C, S156E and S156F
4.10 ratio, tags S157C, S157E and S157F
4.30 ratio, tags S421C, S421E and S421F
3.73 ratio, tags S406C, S406E and S406F
3.73 ratio, tags S409C, S409E and S409F
Thor'sHammer
Nov 26, 2014 05:48 AM
tcart38
New Member Introductions
May 10, 2008 02:29 PM
fordmaniac21
1983 - 2012 Ranger & B-Series
Mar 22, 2002 09:37 PM
