weird idleing problem
Old Mar 7, 2007 | 07:40 PM
racsan's Avatar
racsan
my '93 ranger has developed a strange idle problem i just havent been able to get a fix on. its a 4.0 std trans and it will start fine, has plenty of power but just doesnt idle down right. when i dump the clutch to come to a stop it will rev and hold at about 2,500. but as i get to 10 mph it drops to 1,500. if i shut it off and restart it will be at about 1,000, dip down to 600 and go back up to 1,100. my scan tool said it was running lean on both banks and couldnt do a cyl balance test due to a uneven idle. i have replaced both oxygen sensors, the idle-air control valve, the coolant temp sender and the throttle postion sensor. i guess all thats left is the mass air sensor, but i doubt that would do anything. every time i changed something i had the battery unhooked, it would start fine and idle at 1,000 i dont have a check-engine light on, the truck has 103,000 miles on it. has no engine mods. any ideas? i seem to be at a impass.
Old Mar 7, 2007 | 08:09 PM
RangerPilot's Avatar
RangerPilot
Vacuum leak. It's a pretty typical vacuum leak when it causes the lean bank codes, plus high idle. Check for broken or cracked vacuum hoses.
Old Mar 7, 2007 | 08:52 PM
danger_ranger26's Avatar
danger_ranger26
I agree, check for vacuum leaks
Old Mar 7, 2007 | 09:10 PM
racsan's Avatar
racsan
im wondering......if i used a propane torch (no flame, just gas on) could it help find a leak? heck, whats a torch kit compared to all the other stuff ive put on that aint worked. what puzzles me the most is the rpm drop from 2,000+ to 1,500 as soon as the speedo drops below 10 mph. that just doesnt make sence.
Old Mar 8, 2007 | 09:42 AM
rubydist's Avatar
rubydist
It also could be the iac that is sticking.
Old Mar 8, 2007 | 10:12 AM
fflintstone's Avatar
fflintstone
I used to do leak test with a little 'oxy-propane/map gas' set up with the little bottles the size of plumbers propane bottles. It had a long small hose and a fine tip like a brazing torch(it's intended for brazing and did a good job on small body holes). I'd turn just the propane on(of course) and submerge the tip of the torch in a glass of water tille the bubbles were a steady stream(you don't need a lot). Then it was really easy to get around the engine compartment with it. Found a bad vaccum hose once in a real hard spot to get to once that I would never have gotten to with a plumbers torch.
Old Mar 8, 2007 | 11:11 AM
97ranger xlt's Avatar
97ranger xlt
Lightbulb
check pcv valve .. it won't throw a code.
Old Mar 10, 2007 | 04:47 PM
racsan's Avatar
racsan
new pcv valve and hose, stilll the same has codes 172,136, & 538 in memory. only three things left, mass air sensor, map sensor or the computer processor itself. havent found any vaccum leaks, checked the vapor canistor as well. may have to visit a stealership.
Old Mar 24, 2007 | 11:25 AM
racsan's Avatar
racsan
finnally got it figured out, turned out to be a failed gasket. the fuel rail which is sandwiched between the upper and lower intake had the gasket between it and the lower intake pulling into the intake ports at the front and rear. idles fine now, i ran a compression check before i started to see if i had a problem there, its looking good for 104k with 185 on 4 cyl and 175 on the other 2. glad i didnt need to pull the heads. i pulled the lower intake just because i was that close and had the gasket, no issues there, looked good and clean. had the camera but ran out of battery before i got it compltely tore down. had the hood off, that made things easier but who knew a ranger hood could weigh so much.
_________________
