Help
Old Mar 7, 2007 | 06:53 PM
redneckboy's Avatar
redneckboy
Help
Put blue thread lock on the hpx today and did the ccv mod today. Drove it now im blowing a lot of blueish white smoke from the exhaust. Pulled the dipstick and i think there was a little bit of green on it. Performance wise it is running good but im affraid i blew the headgasket i have no clue what happens but from everything i have read it suggest this am i wrong?
Old Mar 7, 2007 | 06:55 PM
SpringerPop's Avatar
SpringerPop
Remove the CCV mod and tell us what it does. If the crankcase doesn't vent to the atmosphere for some reason, you'll get the symptoms you describe.
Pop
Old Mar 7, 2007 | 06:58 PM
redneckboy's Avatar
redneckboy
ok i will. i put my hand over the end of the hose and pressure built up but not much i will i sure hope that is what it is there is one place the hose is kinked a little so maybe thats it.
Old Mar 7, 2007 | 07:01 PM
CSIPSD's Avatar
CSIPSD
yup any kind of restriction will cause oil to leak past the Compresser oil seals...
Old Mar 8, 2007 | 12:30 AM
redneckboy's Avatar
redneckboy
Question
That was the problem thank you. I was worried.
