1978 - 1996 Big Bronco
power window motor problem
Old Aug 6, 2002 | 11:45 AM
Pilotrick's Avatar
Pilotrick
Old Aug 9, 2002 | 04:54 PM
steellll's Avatar
steellll
greetings from sunny connecticut.
i just replaced the power window motor on the drivers side of my 89 xlt. fyi, this is one real pain in the *** job. after getting it all bolted back up it's working fine but has a pretty good vibration on the way up. pretty smooth going down, but a little rough going up.
first time i have ever done this job and everything looked like it went back together right. any ideas?
best regrads, steellll
Old Aug 9, 2002 | 06:28 PM
yankeebronco's Avatar
yankeebronco
STEEL
i just did the same thing , it had a vibration going up.. all i did was put alittle litham grease in the track and on the gear, i think it was the track that did it , and its been workin fine for 3 weeks
good luck ,,,,, any tip's you have let me know , any thing help's to keep them bronco's that we have workin as good as they do...
89 bronco 351w c6
Old Aug 9, 2002 | 09:40 PM
8996EBBroncos's Avatar
8996EBBroncos
You can get some silicone spray lubricant that will work fine. It's what I use anytime the windows are not running up and down smooth.
