1978 - 1996 Big Bronco
O2 Sensor
Old Aug 10, 2002 | 04:34 PM
Escopeton's Avatar
Escopeton
O2 Sensor
Hey all:
I got a 84 XLT 351W with a four barrel 4180 carb 4X4 Bronco. I am in the process of getting it to run well, a slow task but a rewardful one. I was going to put in a new 02sensor and couldn't find the old one according to the manuals I have. Does this model have one or the prior owner took it. Where should I look?
Thanks in advance for the help. Thomas.
Old Aug 10, 2002 | 05:11 PM
Pilotrick's Avatar
Pilotrick
O2 Sensor
I don't believe 84 351's had an O2 sensor. Usually only vehicles that have fuel injection are going to have an O2 sensor. Hope this helps and Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Old Aug 10, 2002 | 08:35 PM
78bronco's Avatar
78bronco
O2 Sensor
my 84 f-250 with 351w had an 02 sensor, it was on the back of the passenger side manifold. take a look from under the truck.
Old Aug 11, 2002 | 07:30 PM
Oldfordtech's Avatar
Oldfordtech
O2 Sensor
Ford did not use electronic engine control on a 351w 4-v. A 351 2-v had EEC. I suppose some one could have put a 4v on it like my Son did on his. Then the EEC would not be used so don't worry about it if that is the case. The easiest way to tell if you have EEC is to look for the PCM either under the seat or dash, or an egr valve with a sensor on it. There are many other ways.
Old Aug 11, 2002 | 07:52 PM
F250NUT's Avatar
F250NUT
O2 Sensor
