Can anyone tell what info is needed when tring to order a Dashmat and it ask about a Light and Climate sensor? I'm so confused!!!!! LOL Thanks for the help
Hi and welcome to FTE Half Breed. See ya on the boards!
What year and model truck do you have? My truck has AutoLamps and EATC (Electronic Air Temperature Control). There are sensors up on top of the dash that these systems use. This is what the manufacturer is asking about. Good luck!
Yes, there will be a 10mm dark circle in the top of the dash close to the windshield that is the light sensor. Then the temperature sensor will be under a small grille about 20mm square. Does your truck have either of these options?
