Offroad & 4x4
'78 Bronco steering box
Old Mar 6, 2007 | 07:46 PM
todder53's Avatar
todder53
Ok i'm going to add Hydraulic Assist Ram to my steering. I found a thread on a other site about taping a steering box. My question is it was on a '88 Bronco box would taping it be the same as my '78???
Second question my fluid in my power steering pump boils out after about 1 hour on the trail. I'm running D44, 4.56 gears, locker, and 36" tsl's. I already added a tranny cooler on the low pressure side and its still doing the same thing. I can't turn locked up 36's with a 14" wheel. What could this be?
Old Mar 6, 2007 | 08:01 PM
fishmanndotcom's Avatar
fishmanndotcom
its very similar! i am actually working a box right now for a buddy, tapping it and rebuilding it for him.
its all pretty much the same if you understand the concept.
you shouldnt be running hot if you have a cooler... what size cooler is it? get the biggest one you can fit on the radiator. mine is an external rad cooler from a ford truck in a j-yard i bought for $5. it cools my fluid and i am running hydro boost brakes, 2" ram, and hydro assist! you should have no problems. only thing i could suggest is mount your cooler somewhere where it can get ample air flow and add its own small yet powerful elec fan!
what p/s fluid are you running? valvoline syn power is prolly some of the best stuff out there!
o yea... what pump are you running? if its the stocker ford pump that squeals you need to go ahead and swap it out! go out to a j-yard ad get a couple of canned ham saginaw p/s pumps! they can be had a dime a dozen and will outlast the truck (might think about resealing it)
-cutts-
Old Mar 6, 2007 | 08:12 PM
todder53's Avatar
todder53
Good deal about the steering box i never really got into them at all. Do you think you can get a couple pics up of where you tapped it???
I think i'm just gonna swap it out i got a canned pump laying around.
Old Mar 6, 2007 | 09:36 PM
fishmanndotcom
you NEED to do the canned ham pump! lol
is this what you read? (remove the space) http://www.ful lsizebronco.com/forum/showthread.php?t=10413
and look at this, it helps explain it (remove space) http://www.pir ate4x4.com/tech/billavista/HydroAssistTap/index.html
-cutts-
Old Mar 6, 2007 | 09:41 PM
todder53's Avatar
todder53
Yeah the first one is the one i looked at the second ones really helps thanks. So those canned ham pumps pump enough for like a 2.5 cylinder or should i go smaller?
Old Mar 6, 2007 | 09:46 PM
fishmanndotcom
lol, no no no! 2.5 is WAY to big. in fact my 2" is really too big even with the WTO pump mods. get 1.5"-1.75" ram, they are much more responsive. for a street truck thats what you need!
-cutts-
Old Mar 6, 2007 | 09:56 PM
todder53's Avatar
todder53
Ok sounds good to me hope everything works out. Just have to wait for all the snow to melt now to get my truck out lol.
jerry73
Sep 10, 2013 03:36 AM
lamar804
Oct 9, 2011 08:45 AM
1oldtimer
Jun 17, 2010 02:31 PM
Craigwell
Nov 15, 2009 04:18 PM
Julien_79_F150
Oct 23, 2006 12:48 PM
