1978 - 1996 Big Bronco
manual windows for bronco
Old Aug 13, 2002 | 02:50 PM
WALLDOG18's Avatar
WALLDOG18
Old Aug 13, 2002 | 02:53 PM
valcaia22's Avatar
valcaia22
I have a 1990 full size bronco. Can you get doors with manual windows on it for that year? I have electric windows on my doors right now.
Old Aug 13, 2002 | 03:45 PM
cwade3's Avatar
cwade3
[updated:LAST EDITED ON 13-Aug-02 AT 04:49 PM (EST)]if these doors are the same as the f150 from 88 to 91, you can install the hand crank regulator and hand cranks into the existing door with no modification to the door itself. however you will have to get door panels for this set up unless you want to cut the panels you have now. the panels that will fit is also 88 to 91. i did this on a 90 f150 xlt using the 88 4 door 350 assembly and panels the whole assy. bolted right up with no drilling. if you find panels that are the same color even if they are extremely faded, dep makes an interior paint that should closely match. started by lightly sanding with 500 grit sand paper to get the oxidation off, then used 2000 grit to finely sand the rough marks out. use the dep cleaning/soap product dry then paint. i did this cause it was cheaper than forking the bucks up for motors that may or may not work. hope this helps, good luck
