1978 - 1996 Big Bronco
shaking around 30-40mph
Old Mar 6, 2007 | 11:41 AM
broncojoseph's Avatar
broncojoseph
Have a '93 Bronco 5.8 with OD transmission. This last week the truck started shaking between 30-40mph, not below or above those speeds. Only seems to shake when accelerating, not when coasting at those speeds. Any ideas? Thanks.
Old Mar 6, 2007 | 01:34 PM
lostin90s's Avatar
lostin90s
Check u-joints .They are under more stress taking off. If was bad tire it should show up both accelerating and coasting . Good luck
Old Mar 6, 2007 | 01:50 PM
sivart's Avatar
sivart
I just went through that a couple of weeks ago. It turned out to be a u-joint on the rear drive shaft up near the transfer case. I had to stick a small pry bar in there to actually find it because it felt OK when I checked it by hand.
Old Mar 8, 2007 | 09:44 AM
broncojoseph
The tie-rods, u-joints, and ball-joints were all checked out and tires were rebalanced. Still shaking, also at 50-65mph hear kind of a rubbing noise. The shaking and noise only occur when giving it gas, not when coasting. Could it be a motor mount or transmission mount?
Thanks - Joe
Old Mar 8, 2007 | 10:28 AM
poffutt's Avatar
poffutt
Check the U-joints again. It has to be that.
Old Mar 9, 2007 | 12:51 PM
peppersfords's Avatar
peppersfords
I had the exact same problem. It has to be the U-joint. when you checked the Ball Joints was there any movement?
Also (possibly), if it was the tires that needed rebalancing...the tire tread could be "cupped" try rotating your tries.
Old Mar 13, 2007 | 10:51 AM
broncojoseph
Thanks for all your help.
It was 2 of the u-joints near the constant velocity joint.
Old Mar 13, 2007 | 03:19 PM
peppersfords
I know how annoying that was....the best part is I had a mechanic tell me I needed to have all four of my ball joints replaced.
Old Mar 13, 2007 | 04:43 PM
broncojoseph
They actually told me the frontend is tight. Which is pretty good for a '93 with 144k miles on it.
