eats starters
Old Mar 6, 2007 | 09:58 AM
Jim88554's Avatar
Jim88554
Exclamation eats starters
<TABLE><TBODY><TR><TD vAlign=top width="100%">Hi E1
im new here and need help, im gonna go look and see if i can find the answers i need here some where?
i may need help to search for what i want to find or i may stumble on it.
my 1st problem is starter related.
i have a 1986 f150 w/ 6 cyl 300, 3 speed c6 (my sons truck). we replaced motor in it and started having starter problems, after using truck for ?
not long, (have not attempted to work on truck for over a year so recolection may not be 100%). starter went out, we replaced starter, after a few days starter went out again we replaced it only to last a few days. this has happened repeatedly. the auto parts store would not replaced the starters because nothing was wrong with them. i took starter to remanufacturer and they showed me the drive gears were bad (hook up starter on work bench, hold 2x4 against gears and energize, starter motor runs but gears dont turn 2x4 binds. we can replace gear drive in starter and truck will start a few times and then we have to replace gear drive in starter again. some how there are holes in tranny housing from some thing being thrown by flex plate? (bell part around torque converter) have tranny on way should it today am going to replace tranny and see if we still have problem. I think i will. my brother has another 300 that we will change out with if we do to try to correct. but im baffled as to what the problem may be, have replaced flex plate already but did not helpn NE1 have any suggestions?
Thanks Jim
</TD><TD vAlign=top align=right width=305>******** type=text/javascript><!--Serve300x250( 0, 101, "9664575281" );//--></SCRIPT>******** src="http://pagead2.googlesyndication.com/pagead/show_ads.js" type=text/javascript></SCRIPT><IFRAME name=google_ads_frame marginWidth=0 marginHeight=0 src="http://pagead2.googlesyndication.com/pagead/ads?client=ca-pub-6539444466526181&dt=1173196215625&hints=eats%20sta rters%20-%20Ford%20Truck%20Enthusiasts%20Forums&lmt=1173196 215&alternate_ad_url=http%3A%2F%2Fcampaigns.ford-trucks.net%2Fcampaigns%2F300x250.html&format=300x2 50_as&output=html&channel=9664575281&url=http%3A%2 F%2Fwww.ford-trucks.com%2Fforums%2F587734-eats-starters.html&color_bg=FFFFFF&color_text=000000&co lor_link=0000CC&color_url=0000FF&color_border=FFFF FF&ad_type=text_image&ref=http%3A%2F%2Fwww.ford-trucks.com%2Fforums%2Fsearch.php%3Fsearchid%3D2056 28&cc=100&u_h=768&u_w=1024&u_ah=738&u_aw=1024&u_cd =32&u_tz=-300&u_his=17&u_java=true" frameBorder=0 width=300 scrolling=no height=250 allowTransparency></IFRAME>
</TD></TR></TBODY></TABLE>
__________________
Old Mar 6, 2007 | 10:51 AM
tjc transport's Avatar
tjc transport
i ain't rite
when you replaced the engine, did you put the spacer plate between the engine and trans?? it sounds like you have the starter to far into the bell, and the flexplate it breaking the drive.
Old Mar 6, 2007 | 11:03 AM
Jim88554's Avatar
Jim88554
yes i did and what little appears on teeth seems to be in approiate position
Old Mar 6, 2007 | 11:05 AM
Jim88554's Avatar
Jim88554
the teeth on the bendix are good, its the clutch inside the bendix that fails
Old Mar 6, 2007 | 11:09 AM
mtflat's Avatar
mtflat
Also sounds like there is/has been debris in the bellhousing - lost bolts/nuts/pieces of ring gear, etc that get picked up by the flexplate and tossed against the sidewalls. Clean out the bell and block recesses when you have it apart.
edit: FWIW, I've also found that parts houses carry at least two different lines of accessories like starters. After a similar round of troubles several years ago, I asked my counter guys at NAPA if they carried a better starter. They do, but most people on the street are looking for a cheap fix. Now the guys know if they carry more than one level of a part that I want the best one. Costs more initially, but is a lot cheaper in the long run.
I happen to have a great NAPA store here.
Old Mar 6, 2007 | 11:13 AM
Jim88554's Avatar
Jim88554
yes thats what caused hole in tranny but problem started b4 the holes were in tranny
i was thinkin bent crank in rebuilt engine but when running does not seem to run rough (out of balance)
Old Mar 6, 2007 | 11:32 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Call Matt Vose at SPI Distribution 1-800-361-1714 and tell him your problem. He carries both new and reman starters. Tell you are from FTE when you call. It sounds like you are getting some of those "lifetime" starters. I have had issues with some of the parts places myself. Their counter people are only told how to test to their specs, and don't have the equipmet to do a stall test on a starter.
Old Mar 9, 2007 | 10:15 AM
Jim88554's Avatar
Jim88554
after closer examination of bendix teeth i found
1) the first 2/3's of teeth about the thickness of flex plate are slightly worn looks normal for depth of engagement.
2) a little over 1/2 way down the face of the tooth. was worn, ehh maybe a little shy, might slip easily.
I saw in another thread there are different numbers of teeth on starters 9 and 10, and there are a varity of teeth on a flywheel/flex plate.
I have bought 2 flywheels 1st we thought we might have bent it when we tightened tranny and torque was not seated correctly.
2nd was going to replace tranny im wondering if it was wrong???
stupid thought. any way got it out and was looking at flex plate and the strip between 3 oblong holes was bent slightly, so rather than take the chance got another.
all 3 flex plates are the same with 164 teeth.
the starter has 9 teeth.
Is it possible i have the wrong starter, i need 1 with 10 teeth?
and why would parts stores only list 1 starter?
Old Mar 9, 2007 | 10:39 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Thanks for the call man. I hope that helped. If you cant find the drive local just give me a shout and I can get you that new unit, probably work a little better deal w/o my boss hovering over my shoulder...lol
Old Mar 9, 2007 | 01:17 PM
Jim88554's Avatar
Jim88554
thanks really appreaciate the help
found 1
the 9 tooth drive measures 1.000 out side to outside and the 10 tooth measures 1.090
.090 diff 3/16" sry 3/32
napa carries a 10 tooth and a 12 tooth, they told me about an alternator rebuild shop, called him and he had 1
turned out the owner of the alternator shop is 1 of my distant cousins i have never met till now!
Old Mar 11, 2007 | 06:44 AM
Jim88554's Avatar
Jim88554
got 10 tooth bendix installed, and all hooked up.
Sounds great, no grinding, very smooth.
havent got truck started yet no spark will do some more diag. then start new thread if needed
Thanks all, the help is really appreaciated
Old Mar 11, 2007 | 07:20 AM
Archion's Avatar
Archion
Good Deal!!
