Front locking hubs-Which are the best?
True to what the KTM rider said...I live in Pittsburgh PA...where its rain, snow, doom, and gloom 80% of the time. If I lived in a place that was flat, warm, and typically dry....like say anywhere else on Earth but the North-East....I may have learned to unlock hubs. It just does not make sense here to unlock them. There is another 4-8" of snow coming today.....4x4 all day long.
If ya live in Texas....you most likely dont need to lock em in but once in a blue moon when you happen to go out in a flat pasture and get stuck in a giant cow patty.... those guys dont need to be perma-locked!
Originally Posted by GONE4X4
-just remember--leaving them locked engages everything, which ya don't wanna do on anything but a loose surface!!
When the hubs are locked, it simply means that the front axles are connected to the wheels and the front diff is turning. This can cause some extra vibration due to the front axles turning and of course put wear on the front drivetrain, but other than that there is no problem. When you are in 4 with a part-time transfer case, the front and rear driveshafts have to spin at the same speed. This is fine in a straight line, however when you turn there has to be some wheel slip otherwise you will break parts.
Also, WARN hubs are the best in my opinion. I swapped the auto hubs on my Explorer over to Warn manuals and it is the BEST thing I have done for that truck.
Also, to the guy that complained about manuals, you have to remember to lock the hubs if you even think that you will need 4 wheel drive, that way you don't get yourself into a situation where you need to get out in the middle of a mud pit, on a boat ramp or in deep snow.
The Excursions are still working 170K miles, knock on wood.
F250's lasted until 150K miles, replaced with Warns.
F350 was bought at 120K miles with Warn Premiums.
The F250's Warn's are much easier to turn than the premiums as they have be turned a full rotation when the regular Warns only need to be turned a little ways.
With the deep opening on the F350 dually front had my mechanic make me a couple tools to turn the hubs and they work excellent. One goes in each door, very simple to use.
With both Warns the 4x4 does not engage unless the fronts are locked in. No automatic feature unless you go with Fords hubs.
i found that the OEM hubs non auto hub were $430 each ( canadaian dealership) and the warn premium hubs were $350 pr... no brainer in my opinion. I kept mine locked when the raods were bad and free when they are not . Usually locked for the weekend hunts and free back and forth to work all week.
rat!!! you should be able to pick warn premies up for a whole lot less than that!!
i just put warn in my search and found-em for $171.00
#30
