Sponsored by: Auxito
question
Old Mar 6, 2007 | 04:05 AM
mojavepa's Avatar
mojavepa
Talking question
i have a 99 f150 4x4 5.4 gas with right around 125000 miles and the other day i was reading a spec sheet that said it only has around 200 hp but the later years like 03 and up had 300 hp with the same motor soo.. my question is if i got my comp reflashed would that retune every thing and bump up my hp or wut? power is everything around the hillbillys of family members i have>
Old Mar 6, 2007 | 04:50 AM
phil6608's Avatar
phil6608
Welcome to FTE,
No , you can not just have it reflashed to get that extra HP.
In 04 they came out with the 300 HP rating. It's a little different from your 99.
However you could mod your 99 and get close to 300. It all depends on how much money your willing to spend.
For about $3500 to $4000. you could do a Lightning conversion on it and make over 350 HP.
Or you could go with mods like electric fan /open exhaust/ K&N intake or other and tuner or programmer. All of this will get you close to 300 HP.
Old Mar 6, 2007 | 05:37 AM
rsylvstr's Avatar
rsylvstr
did you check the spec sheets on this site?
my 2001 makes more than that and it's the same 2valve like yours....
then again, i now have a dual exhaust, CAI and Power Programmer...for a few ponies.
Old Mar 6, 2007 | 12:54 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I thought the Pre-2004 5.4's made 260HP and the 4.6's made 230HP?
Old Mar 6, 2007 | 01:21 PM
phil6608's Avatar
phil6608
Yes,that was the stock rating for the pre 04s
