1978 - 1996 Big Bronco
tire advice
Old Aug 8, 2002 | 09:32 PM
yankeebronco's Avatar
yankeebronco
tire advice
Old Aug 16, 2002 | 08:31 PM
daspud's Avatar
daspud
tire advice
94 bronco stock wheels no lift. tire size now p265/75/15 , will switching to 31 /10.5/15 effect ride or handling. will they rub on tight turns. will an lt tire ride rougher. the 31 looks a little shorter and wider, thanks
Old Aug 16, 2002 | 10:59 PM
83bigbroncoguy's Avatar
83bigbroncoguy
tire advice
The 31x10.50 is a good tire. I had some on my '83. The ride is good, and you won't have problems turning. According to the tire size calculator on www.4lo.com, the 265/75/15 is 30.6". The 31/10.50 ends up being about the same size.
Old Aug 17, 2002 | 04:36 PM
tothfngclw's Avatar
tothfngclw
tire advice
As the above post pointed out they are the same size. Check your door for info on tire size. Mine has a listing for both.
