Proper Weight for Engine w/ Low Pressure?
Yes, he said that, but I had never seen a 30W-30 before, which I guess is a spec for a remanufactured oil.
Since I never have used a remanufactured oil, that is why I never saw it before. I mean, what's the difference in price? Was it worth it?
Since he blew up his 327, one less Chevy on the road, because of his bad decision. What a waste. Unneedlessly.
Ed
Back in the 80's & 90's when GM & Ford began specifying 5W-30, it was rare to find it in the stores, but by the time I bought my 94 Taurus 3.8L, it was to be had almost anywhere & 10W-30, which had been the mainstay multi-vis crank case lube, since the mid 50's, was on the wane, as the 5W-30 had proven itself.
Now when Ford began specifing the 5W-20, it was very difficult to find around here & most folks, including most Dealers, didn't trust it & still put in 5W-30 or 10W-30.
Most have now come to accept 5W-20, if specified by the mfgr, as ok & safe to use.
Ford has back specified most but not ALL engines to use the 5W-20. My 94 Taurus 3.8L, is ok to use it, but not my 99 Ranger 4.0L pushrod engine!!!! So I just continue to use 5W-30 Havoline in both of them, along with Motorcraft filters.
It's getting so danged complicated now days to know what's safe to use, because of all the different engine designs & oil recipe's, & changes thereto, so imo just stay with what your vehicle manufacturer specifies & recommends, for the service grade, viscosity range & OCI, that fits your driving conditions, drive cycle, & driving style.
If you want to safely go outside those guidelines, then establish a base line with several UOA's to determine how the engine, oil & filter are doing, in your particular engine, under your conditions!!!!
Everyones conditions will likely be different & a particular oil or filter may not safely bridge all those conditions, thus the UOA baseline.
Just some some thoughts for pondering.
Does that change anyones mind set?
BTW, Ill be adding Lucas Oil Stabalizer soon and probably change to 10w-40 or 20w-50 for my next oil. (whcih do yall think? Coldest start will probably be above 50 degrees)
Might also consider a heavy duty engine oil, one of the dual rated (gas / diesel, SL/CI-4) oils, like Valvoline Premium Blue, Shell Rotella, or Mobil Delvac. They come in gallon jugs at all the parts stores in 15w40. Will be more robust and probably around 15 cSt. Easy year round use in TX I would think.
I would be more inclined to run Valvoline Synpower Oil Treatment (VSOT) than the Lucas stuff. Not sure how good Lucas is. Some discussion at the oil guy site. Full bottle of VSOT or even the Maxlife Engine Protector (on clearance at some Big Lots) will raise you 2 cSt to about 12.5 or borderline between 30 and 40 wt.
I'd kinda sneak up on the viscosity change, rather than jump right into a BIG change.
Are you hearing any untoward, cold or warm noises from this engine????
If you change to a heavier weight lube, let us know what it was changed to & how it goes.
I'm not saying if say, you are getting a peak 15 MPG, that by using a thicker oil, it will drop to 9-10 MPG. However, it will drop, and that peak 15MPG will be less. LESS MPG = fuel guage getting to EMPTY, SOONER rather than later. That is a fact. Compared to the 10w30 oil, you'll lose MPG, not gain MPG. Hence, everything I said, is true. You'll go less miles, fill up or stop for fuel sooner. If that is fine with AmericanMade (as I stated) then he can use the thicker oil, knowing this.
You seem to think, I feel a engine will not start or run with a thicker oil, or fuel mileage will be night and day difference. I knew that. Again, if his MPG is 15 max. (a made up number) he will not achieve 16.6 MPG using a higher viscosity oil.
Ed
Duh! Please, don't attempt to talk down to me! It's not the way to go.I never said mpg would go up using a more viscous engine oil (yes, I do recognize that you are using the term "thicker" for effect, but that effect is lost on me because "thicker" = more protection at full operating temperatures to me, sir. Also, Multi-viscosity oils have much less difference in "thickness" at full operating temperatures than you would imagine). On the other side of that coin is the fact (I have proven it to myself, anyhow) that the increase in mpg using "thinner" (less viscous) engine oils is miniscule to nothing over the long haul and there are risks which are not openly addressed.
I will give you that if you never fully warm your engine driving mostly short trips of less than ten minutes, then you might enjoy a tenth or two increased mpg. But if you are like the majority of drivers whose trips last 30 minutes or more, the savings in energy taper off as the engine approaches full operating temperature and may even reverse to increased energy losses due to substandard lubrication if sustained full temperature highway driving in warm to hot temps is necessary.
Pawpaw: Just remember that the middle ranges of both oils are the same, the end points are different, which only have an effect when engine temps reach the extremes...which seems to me is what we are looking for.
This is sort of like playing doctor/druggist. If the patient was healthy, we wouldn't be talking here. What is good for a healthy patient is not necessarily what's good for the suffering patient. Instead of high blood pressure we're dealing with low oil pressure.
Try the 15W-40 or 20W-50 if it is hot outside or you're working it hard.
If you don't want me to say the oil viscosity you prefer is "thicker", "thick", "heavier" "heavy" ect. then what term do you prefer that I use? I don't say anything for "effect", I simply post what I feel, and know to be closer to the truth than not.
You seem to think that "thick" (is that okay to say?) Wait... You seem to think "your preferred oils" offer better protection in hot weather. That is dated thinking, and I even thought so back in the 60s, and 70s. It simply is not true. In fact, the new Mustang GT500 calls for a 5w20. Those engines are made to run extremely hot, and the 5w20 oil can and will handle the heat. Otherwise, Ford would have oil related engine failures left and right in desert states, ect.
Once you get your dated thinking abolished, you'll realize your mistakes when it comes to modern engines and today's oils.
I never saw an oil that said 30W-30 I may have misspoken on the viscosity. It was 1982, maybe it was straight 30, so what? on the quart or jug container. Perhaps that was your problem, a cheap Yeah, it was cheap, I told ya it was reman. oil, that = cheap! oil(I noticed you didn't mention the brand It didn't have a recognizable brand, but hey, it was thin!) that was not very good. Hence your 327 went south, and that is a shame. Maybe you'll pay more attention next time(you're preachin' to the choir here, bud, preachin' to the choir! there have been literally dozens of "next-times" since then and I have had exactly two engines croak since then....both were driven and maintained by someone else for the first 100,000 miles, so they were virtual unknown entities when I got 'em. The Ranger 2.3 went to 205,000, so it didn't cost me a dime), and not buy something that says 30w30. That 30W probably pumped like taffy at the local County Fair, when cold, even in the summer time. (That's where you're wrong, Ed, it was thin like vegetable oil, that's how I knew it was CRAP, but I had to get the truck back home to do another oil change. I drove it around seven or eight miles for all that damage to take place.)
What proof do I have? 1973 Dodge Charger SE. 440 CI 4BBL 727 auto, AC (ice cold) dual exhaust, 2 1/2" w/ "H" pipe. Drove Charger from NE Ohio to northern California. Used 10w30 Castrol GTX oil. 65-75MPH cruising speed, with AC blowing ice cold. Plenty, repeat plenty, of passing power. Never ran hot, or overheated, when climbing mountain passes, Interstate 80 in Wyoming, Utah, Nevada and northern California. (I did gear trans down into "2" however, on steep climbs) Purchased Charger in Jan. 1978, second owner, I was 19 years old. Still own car. 53000+ orig miles now. I can reach in and turn the key, and that big 440 will fire and rumble after that brief Mopar starter whine, made famous in the 60s and 70s. I never needed your heavy syrup /tar oils in my engines. I wonder why? (But you see, none of this proves your contention that "thicker" oils affect mpg in any significant way. And by "thicker" I mean 10w-30, 15W-40, 20W-50. I have somewhere a book kept on every vehicle I have owned since 1973 where I kept track of maintenance and every gallon of fuel used (+ mpg's, usually). Frequently I noted the oil viscosity, especially when changing to something different, always comparing effects on mpg's. I got so good at knowing my expected mpg's, I could tell when an oil change was due by the slight drop in mileage. If no oil change was due, I looked for some other cause. I sold oil and grease for a company for several years, learning about their products and the industry in general. I still use their products and have countless personal examples and dozens of customer testimonials about the many products I have introduced to people. None of these are "cheap", but all of them help cut costs of maintenance and repair.)
1987 Aerostar Van 3.0V6 146K+. Purchased van at 17,000 miles. Use 5w30 oil, mostly brand name dino, but I have used 5w30 Royal Purple, 5w30 Mobil 1. Van does not use a drop of oil between changes. AC used, ice cold, in bumper to bumper traffic after a 35-40 mile freeway drive in 105-110 northern California summer weather. 5w30 oil. Van runs normal. Never overheats, garage floor is spotless.
I can give you 4-5 more examples, wifes cars and others I've owned. I have not used a 10w40 oil since 1977, and have had no oil related engine problems / failures with those "demon" lightweight salad engine oils.
Ed
You're talking thicker, thinner, etc.,etc.,etc. You are using 10w-30 and 5w-30! These are today's THICKER oils compared to the 5w-20 and 0w-whatever, unless you're talking about a diesel engine or oil for "high-mileage" engines, like Americanmade's situation. (I haven't even seen 10w-40 on the shelf for maybe ten years.) 10w-30 is not a lightweight, like I said many posts ago, it has been the industry standard since multi-vis oils were originated.
Oh, the remanufactured oil was cheap, I should have known better, but that was 35 years ago, and I didn't know then what I know now. The reman oil followed your precious "thin" design and I knew it wasn't right, but I needed an O.C., so I did it (on site while I waited for a load) just to get home so I could get some better oil. The cheap stuff wrecked that engine in just seven or eight miles. (That was before I "switched" to Fords.)
I have a brand I prefer and you will probably never find it on a retail shelf. You've ticked me off, Ed, so I'm done playing with you. Research my posts if you really want to know.
Kotzy
Where have I ever said that I consider 5w30 and 10w30 "heavy oils"? I have not. Any energy conserving certified oil, I have absolutely no problem with. I would not use a 5w20 oil in my 440, and have found a quality 10w30 delivers peak performance in the big block Mopar. This is a car built prior to cats being used, but the valves on a '73 Dodge were being prepped to run on low lead or unleaded gasoline, even though I used leaded gasoline in it until around '85 or so. By then even leaded gasoline contained very few lead particles in it, until it was completely outlawed in the USA.
10w30 is fine, and my preferred oil of choice in a 60s or 70s era I-6 or V8. You'll never need 10w40, 15w40, 20w50 oils, unless you want to waste gasoline, overwork starter when starting the engine cold, or overworking your oil pump, when it tries to pump those heavy oils, cold. Not winter conditions, either. Summertime too. Those oils are simply making your engine work harder, the crankshaft work harder as the engines tries to make power but has much more internal friction to overcome.
Now if you have a worn engine, high mileage with blowby issues, piston slap, oil burning, all of the above is off. Thick, heavy oils are needed to help seal worn rings, worn bearings, ect. That is when 15w40, 20w50 oils work their magic and do what they are intended to do. In a tight engine, your thick oils are the same as pulling a sparkplug wire off of the plug. Fuel mileage drops. Engine power is reduced. Sure the engine will still start. However, it will not be running at peak efficiency.
That is where I differ from you. I want my engines to run at the best of their ability, whether it's a Briggs and Stratton lawnmower or a full race motor, and everything in between. You seem to settle for close effiency, because your logic is dated with "old thinking" that has become obsolete for the most part.
You might enjoy watching TV on your 13" black and white portable. I'll watch TV on my 13" color plasma TV. Both of us will watch the same program. One of us will be more up to date with modern technology, and will enjoy a sharp, clear color picture. You enjoy a sharp, clear, black and white picture. At one time, I watched black and white TV and b&w TV shows as well. Soon, I discovered I liked color TVs better, while you continued to enjoy the dated TV with black and white technology.
Same premise for motor oil.
Ed
