A New Brownie thread . . .
Old Feb 10, 2010 | 09:42 PM
  #151
bghnkinf250's Avatar
bghnkinf250
Info pops up every once in a while on the internet, or find an old truck shop. A lot of them have their old books they use to order from or can get into contact with the people that have the info.
Old Feb 10, 2010 | 09:45 PM
  #152
460/5's Avatar
460/5
Zombie Survivalist
hey. how much is a good, workin brownie worth?
Old Feb 10, 2010 | 10:24 PM
  #153
cornerwindows's Avatar
cornerwindows
I've been looking for a while and found a few 5531s or 5831s in the $250-600 range on craigslist. Most don't have shifers and none I've found have been willing to guarantee the condition. I've seen a couple up near a $1000, but they don't seem to offer anything a cheaper one does...just overpriced
Seen a few cases where you can by a Brownie for cheap...and they'll throw in the rest of the truck for free.
Old Feb 10, 2010 | 10:27 PM
  #154
460/5's Avatar
460/5
Zombie Survivalist
well, how bout one that is in a daily driver with the correct shifter?
Old Feb 13, 2010 | 11:30 AM
  #155
cornerwindows
Dana Spicer 5831 b auxiliary transmission brownie lipe : eBay Motors (item 160403056383 end time Feb-19-10 14:44:51 PST)
Here's a link to some 5831's on ebay
Old Feb 13, 2010 | 03:15 PM
  #156
460/5's Avatar
460/5
Zombie Survivalist
those look like they are in pretty rough shape...
Old Feb 15, 2010 | 08:24 PM
  #157
joe_13894's Avatar
joe_13894
Originally Posted by DrCharles
Front driveshaft is just two yokes that slip-spline together.
For a tiny bit more money you can get full flexibility. Just U-jointing together the two yokes allows for angular error, but no side mis-alaignment.
You can use a CV-joint center yoke like this:
They'll allow for frame flex without stressing bearings in either gear box.
They are about $35. For 1350 U-joints they add 2-7/8" total length.
Old Feb 16, 2010 | 07:56 PM
  #158
DrCharles's Avatar
DrCharles
What stress would there be? There is a U-joint on the back of the NP435, and a U-joint on the front of the 5831B, and a slip-spline between them (the yoke from the NP435 has male splines, which mate with the female splines on the brownie's input yoke...)
so there are already two u-joints. why would I need any more?
Old Feb 18, 2010 | 01:39 AM
  #159
joe_13894's Avatar
joe_13894
I thought you only had one U-joint, sorry. I was thinking slip joint yoke on the rear of the transmission directly to the bronie box.
Old Feb 20, 2010 | 10:47 AM
  #160
oldbrokecowboy's Avatar
oldbrokecowboy
Question
Has anyone found a reliable source for shifters for these aux. trans? Seems that they're harder to find than the trans. OBCB
Old Mar 1, 2010 | 10:53 AM
  #161
papecat's Avatar
papecat
Originally Posted by acheda
Way back at the beginning of this thread I reminisced about the small Brown-Lipe auxiliary trans that my Dad had in his 1951 F-1. It was small -- appropriately sized to a light-duty pickup. The Spicer three-speed auxiliaries are a medium-duty transmission -- if you use one of them as a splitter, you are carrying at least a hundred pounds of extra cast iron around, and also have a lot more bulk to deal with.
this has me very intrigued... I have a very small brownie that I have no info on, I cleaned it all up and only see the case markings C30-16-118-8. It is a 3 speed unit. The OD and UD have approximately the same ratio gearing, about .75:1 and 1:.75 checked when turning by hand.
I see that on the 5xxx series spicer cases, the case marking starts with a "C60"
This unit in my vehicle was installed in the early 70's if not right when the truck left the lot in '72... It has a nice 2 rail / gated three position shifter. Since the Brownie is aft of the divorced NP205, the unit is only really to be used as an extra highway gear or for splitting. I have double overdrive now combined with the 5 speed.
It is a dodge w200 crew cab but I've found the FTE forums a valuable active wealth of info over the years...
I am looking to get more specs on my brownie, my cummins 5.9 might be putting out too much constant torque for the unit so I'm really only going to use it for empty cruising to get better MPG. In direct it just acts as a carrier bearing.
Old Mar 5, 2010 | 08:05 AM
  #162
cornerwindows
That unit looks just like the Watson model 43 in my 49 Chevy COE. Mines a 3 speed, UD (about 2:1), Direct, and OD (about .80).
Old Mar 22, 2010 | 04:19 PM
  #163
paintstikker's Avatar
paintstikker
Hey all, I am trying to find information on a Watson M40 aux. trans; I found one at the local yard and it is really small compared to any other brownies I've seen laying around or on trucks. The tag is beat up and has tons of gunk on it; I scraped off enough with my knife to read Watson Transmissions, model M40. There was a serial number, but I didn't get a chance to take it down. If anything, I'll run over there again this week to take a better look at it, but I still would like to know the ratings on this trans; I'm looking to put one behind a Detroit Diesel 4-53N with a NP435 trans and Dana 20 trans case.
Old Mar 22, 2010 | 04:30 PM
  #164
papecat's Avatar
papecat
Wow it is an old unit then I guess - another member on Pirate also confirmed it is a watson model 43 M1. I'm curious about the load ratings of these watsons as well.
Old Mar 22, 2010 | 05:43 PM
  #165
acheda's Avatar
acheda
Shiftin' . . .
It was mentioned a long time back (in this thread, I think), that on a 3-speed brownie with two shift rails, an old-time 3-speed floor shifter can be used without much special work, although a lot of minor fabrication to mount it and provide shifter rods is necessary. None of this work is beyond the average truck owner that can do a little cutting & welding. For a 2-speed, a cable shift with a big **** on/under the dash is used. I learned to drive on one of these and it is not bad at all once you get used to it.
