1978 - 1996 Big Bronco
window tint ?
Old Aug 16, 2002 | 07:01 PM
georgedavila's Avatar
georgedavila
window tint ?
Old Aug 17, 2002 | 09:12 AM
mudder trucker's Avatar
mudder trucker
window tint ?
i bought a back window for my 79 bronco, it was at a garage sale. it has that film type window tint on it, is there a way to remove it before i put it back in the gate. thanks mudder trucker.
Old Aug 17, 2002 | 10:39 AM
CityBronco's Avatar
CityBronco
window tint ?
The degree of difficulty on removing the window tint will depend on how long the tint has actually been on there and what type was used (cheap or premium tint). Basically start at one edge and begin peeling it back. Some times it will come off in one piece, other times it will tear, which can become a pain. Peel it back slowly! You can take a razor blade and some water with hint of johnson's baby shampoo to lightly scrape off areas that wont peel off. But be carefull as to not scratch your glass and scrape off any of the defroster lines if you have some. Once you have the tint removed, you will need to remove the glue. You should be able to see the glue since your window will be hazy. Take a light scrubbing pad and a spray bottle mixture of water and baby shampoo and get to work. Once you get the glue off, squeegee the window clean and your done! It's a tedious process and something I charge a arm and a leg for when I tint car windows. Most installers will charge you anywhere from $20 to $75 depending on the size of the window. Hope this helps!
Old Aug 17, 2002 | 09:13 PM
SubmarineAZ's Avatar
SubmarineAZ
window tint ?
The guy who tinted my windows said straight amonia would remove window tint and the glue. The fumes are said to be pretty bad but it's supposed to work.
Haven't had to try it yet.
Old Aug 18, 2002 | 03:03 AM
whitebenz's Avatar
whitebenz
Post window tint ?
Ditto on the household amonia.
dj
Old Aug 19, 2002 | 11:48 AM
RAzaRazor's Avatar
RAzaRazor
window tint ?
I have always had very good results using Nail Polish Remover (aka Acetone). Best of all, it's like 40 cents.
Peel off the tint, and then just pour some on a cloth. Rub lightly, and the glue comes off instantly. It won't hurt the defroster lines either.
