Aux idle control problem
Old Mar 5, 2007 | 06:27 PM
camdaddy's Avatar
camdaddy
I recently added the High Tech (home made) idle control. After installation everything works fine except at its lowest, it idles at about 1550. I used the 2K pot. I'm certainly no electrical engineer, but it seems to function properly, it just doesn't want to adjust low enough. Thanks in advance for help.
Old Mar 5, 2007 | 06:42 PM
ForemanES's Avatar
ForemanES
I havent done this yet but here is the part list of the instructions I will use.
Single Pole Single Throw Switch. Radio Shack pt# 275-612
5K Linear Taper Potentiometer. Radio Shack pt# 271-1714
Linear PART # for the 2K is Radio Shack pt# 900-8587
2 Single Pole Double Throw Auto Relays Radio Shack pt# 900-2391
2 Wiring Harness Plugs Radio Shack pt# 900-2396
18 Gauge Wire
Does the 5k potentiometer allow for lower idle?
Old Mar 6, 2007 | 09:15 AM
camdaddy's Avatar
camdaddy
Anybody know if the 5k pot is the answer?
Old Mar 6, 2007 | 11:38 AM
Cuda_jim's Avatar
Cuda_jim
Yep, you need more resistance (5K ohms) to get a lower voltage to the PCM. 2K Ohms is not enough to reduce a 5 volt signal low enough IMO.
Old Mar 6, 2007 | 01:23 PM
camdaddy's Avatar
camdaddy
Thanks, I will try that.
