Power steering pump alternative
Old Mar 5, 2007 | 04:15 PM
rbrettctd's Avatar
rbrettctd
Ive got a 79 F150 4x4 400 on 36's with stock suspension. My power steering pump is out. Is there any bolt in or easy replacement that is stronger than stock for my 36s. Thanks in advance.
Old Mar 5, 2007 | 06:24 PM
79-400-POWER's Avatar
79-400-POWER
try the 4x4 forum
Old Mar 5, 2007 | 07:06 PM
Jermafenser's Avatar
Jermafenser
You could swap in a Saginaw pump. Much superior to the factory ones. And they don't whine!
Mil1ion's Avatar
Mil1ion
I would think the aftermarket would have superior performance type parts these days.
check with the steering or 4x4 forums.
Old Mar 5, 2007 | 07:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
All very well and good, but what will you use for brackets? Econolines used Saginaw pumps, F series trucks didn't.
Old Mar 5, 2007 | 07:28 PM
Jermafenser
Saginaw #20-6244 is a direct bolt-in for the F-series. It's a modified rebuilt power steering pump specifically made for 73-79 F-series. Don't go lookin' in junkyards, you won't find one.
Old Mar 5, 2007 | 07:54 PM
rbrettctd's Avatar
rbrettctd
Thanks a ton. Im new here and getting lots of help already. I had wanted a Saginaw but didnt know they made a bolt in. Thanks.
Old Mar 5, 2007 | 09:10 PM
firstonraceday's Avatar
firstonraceday
You can get the pump (#206244) at NAPA. Probably need a pressure hose fitting adapter (#1563) for the pump to mate the high pressure line. And don't forget to add the inline filter in the return line. I did this pump conversion on my 77 in the fall. The pump mated to the original mounting bracket on my 351M with no problems.
Old Mar 5, 2007 | 09:16 PM
Mil1ion's Avatar
Mil1ion
see them here.
http://www.autozone.com/servlet/UiBr...3d800a9124.jsp
Old Mar 6, 2007 | 10:01 AM
beartracks's Avatar
beartracks
I don't see a picture of the Saginaw. I'm considering this swap myself but not till the old one dies. I'm collecting part numbers.
Old Mar 6, 2007 | 01:43 PM
Mil1ion's Avatar
Mil1ion
It's in the E-series section
Old Mar 6, 2007 | 01:50 PM
NumberDummy
But part numbers will only help if you are buying new, pumps don't have part numbers on them, only engineering numbers or the code for the pumps.
1975/79 E150/350 Saginaw pump codes: HBA-GL; HBA-GU; HBA-GV.
Old Mar 6, 2007 | 05:59 PM
69crewcab's Avatar
69crewcab
Is the saginaw pump the "ham can pump"??
I have one in the trash for pickup on friday from my 400 lincoln motor.
Should i be reusing this unit/?
Old Mar 6, 2007 | 06:22 PM
rbrettctd's Avatar
rbrettctd
Is it any good at all?
Old Mar 6, 2007 | 07:45 PM
69crewcab's Avatar
69crewcab
the pump worked fine, i'm just wondering if this is the one for the swap?
