wont start
Old Mar 5, 2007 | 10:52 AM
ihandy's Avatar
ihandy
wont start
hey guys i got a problem i came back to college yesterday and my 94 idi factory turbo ran great. went out to start it this morning and nothing.............it did try to start a few times but would not catch.............need some advice
Old Mar 5, 2007 | 06:21 PM
dieself250's Avatar
dieself250
start with the simple stuff first
how old are your batteries? condition of battery cables,starter,glowplugs,fuel?
Old Mar 5, 2007 | 06:51 PM
ihandy's Avatar
ihandy
the batteries are goodnew cables and terminals it turned over fine glow plugs all work i think i got air in my fuel because after i cranked it and it didnt start i got out and released the schrader valve and no fuel come out.
Old Mar 5, 2007 | 07:56 PM
KJLYPW's Avatar
KJLYPW
Do the lift pump check, IP shut off diconnected, crank starter, 4-6 psi at the shreader valve, (or are you getting fuel out of the schreader valve).? If not time for a new lift pump, or a big air leak in the system. Good luck.
Old Mar 6, 2007 | 11:56 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Look at the return lines between the injectors. If they are painted gray - replace as this is where the air is getting into the system. What happens is that small cracks in the hose will let air into the hose but will not let fuel out. Also check along the frame for rusting steel fuel lines. rust on these lines will form a very small hole to let air into the system letting the fuel return to the fuel tank- replacing the fuel with air.
Old Mar 6, 2007 | 06:23 PM
ihandy's Avatar
ihandy
i blead the system today an am getting fuel now it still wont start. so i guess tommarrow i am checking my manual glow plug system
