Rear door problems
Old Mar 5, 2007 | 10:38 AM
NorthCarolinaExpy's Avatar
NorthCarolinaExpy
Rear door problems
My rear door has quit raising on its own. I can pull it up manually, but it used to raise automatically. I am sure it is the hydraulic openers. Are these difficult to replace?
Old Mar 5, 2007 | 12:49 PM
hotstang's Avatar
hotstang
Not hard
I just fix the one on my 00 Navigator. I took a chance and replaced just the one on the right to see if it was the one that was the weakest. Got the replacement from Autozone for ~$30. Works like new. There are 2 clips that I popped off with a screwdriver before removing the old one and the the clips on the new one I just moved to the end of the tube. Once the rod was in place the clips are easy to slide back. Need to have another person to help hold the hatch open while you replace the strut.
Old Mar 6, 2007 | 05:23 PM
sus1799's Avatar
sus1799
hotstang, was autozone able to give you a part number or did you just get a strut that was the same length? Just wondering because I need to replace the struts on my 97 Expy.
Old Mar 6, 2007 | 07:15 PM
FTE Herman's Avatar
FTE Herman
Pneumatic, not hydraulic. Oh come on now, don't give me too much of a hard time for providing an improved eduction.
Old Mar 7, 2007 | 04:13 PM
hotstang's Avatar
hotstang
Support Lift
OK maybe I shouldn't have used the word strut. The part is made by Mighty-Lift and is called a support lift for the hatch/rear gate. My part # was C95733 but can be easily researched on autozone.com or any other online part store. Hope this helps.
Old Mar 8, 2007 | 11:57 AM
sus1799's Avatar
sus1799
thanks, i couldn't think of the right name for them either but i we were talking about the same thing. Thanks again.
