The close as I can get to what you need is the measurement from the center of the tire to the center of the tire, which is 58.08" for the front and 60" for the rear. I will try and attach the pic.
Thanks. I found a nice frame this weekend but it was about 65" wide. I still might see if will work. It was a 1979 F-150 with a 460, C-6, disk brakes and steering., alot of good parts. Thanks Jesse.
One of our fellow FTE'ers has done a frame swap with something similar. He is building a dually but the principals should be the same. He wrote a very good article with pics. Here is a link to it; http://www.old-fords.com/frameswap/frame1.htm
Man, you guys are great. Thats alot of info. I love the old fords page. I looks like alot of work. but thats what it's all about. the frame I found is a longbed regular cab. I'm going to go ahead and get the frame, the owner wants to keep the engine and trans thats ok a have a couple builders for it. Thanks again. Jesse.
