brakes missing a part
Old Mar 4, 2007 | 06:45 PM
Pa's64f100's Avatar
Pa's64f100
I went to fix my emergency brake and found out that there was a part missing , the arm that the cable hooks on to in the ***. for the emergency brake is not there any ideas where i can get one 1964 f100
Old Mar 4, 2007 | 06:49 PM
customcab66's Avatar
customcab66
You might try your local wrecking yard. Might also try LMCtruck.com
Old Mar 5, 2007 | 12:15 AM
steve442's Avatar
steve442
Good luck, I spent months looking for those arms. I finally got them thru a guy on this site.
Old Mar 5, 2007 | 09:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C3SZ-2A637-A .. Lever, Parking Brake Actuating-Right
C3SZ-2A638-A .. Lever, Parking Brake Actuating-Left
Fits: 1957/67 F100 / 1961/66 T-Bird (prolly fits 1961/64 Galaxie too, but I have no car books)
Old Mar 5, 2007 | 09:52 AM
I_am_fishbait's Avatar
I_am_fishbait
You might try a brake parts vendor.
Old Mar 6, 2007 | 07:57 AM
Customcab's Avatar
Customcab
Number Dummy (Bill) isn't there a variety of years that use the same brake components that one could pull off a salavage yard truck. I believe up too if not farther than 1974 models? Don't quote me on that. My old 66 daily driver was missing those same arms; its rough not having a E-brake with a three on the tree style truck.
Hope this sparks some thought for others to chime in. Because with out a E-brake I think your more than Fish Bait. LOL
Mitch
Old Mar 6, 2007 | 03:26 PM
BobbyFord's Avatar
BobbyFord
Sounds like it's time to upgrade to the wider brakes. You'll need backing plates and axles off of a 68-72 truck. Brakes are wider and parts are available.
Old Mar 6, 2007 | 04:00 PM
NumberDummy
1961/67 F100 2WD Front brakes are 11 X 2" .. 1968/72's are 11 X 3"
1961/67 F100 2WD Rear Brakes are 11 x 1 3/4" .. 1968/72 are 2 1/4"
The front wheel cylinders are larger on 68/72 (1 1/8") .. (61/67=1 1/16"), the rears are the same (7/8"). The parking brake levers are different from 1968/72 and are the same as 1965/72 big Ford/Mercs. Best way to go...donor truck in a boneyard. Then buy new springs and w/c rebuild kits. You can also replace the old self adjusters with new parts, or buy a kit that replaces the self adjusters with replacement components if you remove them.
Size does matter!
Old Mar 6, 2007 | 05:43 PM
acheda's Avatar
acheda
If, after all the above comments, you do not want to upgrade and decide to stick with your original brakes, let me know - I might have an actuating arm in my junk-pile. Do you also need the pin, spring-washer, and the clip? Do you need right or left or both?
Old Mar 7, 2007 | 06:19 PM
Pa's64f100's Avatar
Pa's64f100
thanks for all of your help I don't feel so alone on this subject , I have an old junk truck but I dont know if the part is there It's a good drive from where I am at so i will try that, but If I do not have one ther I will keep you in mind Acheda if you have one I will need the driver side and the pins and springs. Thank you All
Fordby4
Jul 27, 2010 07:18 AM
LIF150
Jun 28, 2010 11:20 PM
irb
Feb 20, 2008 10:15 PM
mbunney
Oct 29, 2003 09:33 PM
