1978 - 1996 Big Bronco
85' Bronco Problems
Old Aug 27, 2002 | 11:58 PM
Tetchy101's Avatar
Tetchy101
85' Bronco Problems
I have a 351 4brl Holley......you know the drill. When I start it say the first time for the day, it starts fine..high Idle leads to lower idle (500-600rpms)and everything is fine....but if I start and turn it off say 3-4 times in an hour as I go about town.....it runs very sluggish for about 15-30 seconds after, if not longer. Does a CARB have to warm up everytime you start it. By sluggish I mean 300-400rpms jumping between the two. To get it to run better I kinda gun it a little bit...sometimes that helps. Any help would be appreciated.
Tim
Old Aug 28, 2002 | 05:16 AM
Hwy Apostle's Avatar
Hwy Apostle
85' Bronco Problems
check your distributer my mid section was loose fitting and coused it to turn a little sometimes fine sometimes high this might be the problem.
also anyone with 80-89 should check there staters in there distributer mine was dry rotted never thought about it and had to replace the entire ignition system because of it.
Old Aug 28, 2002 | 06:34 AM
skatman's Avatar
skatman
85' Bronco Problems
