'97 Front differential
Old Mar 4, 2007 | 05:31 AM
Joe Finn's Avatar
Joe Finn
I have a wah-wah sounding hum that seems to be coming from the front end. I've changed the wheel bearings (hubs), CV shafts and rear wheel bearings with no luck. There is a little bit of play in the front differential bearing on the passengers side where the CV flange mates to the diff flange. The drivers side is tight. Is this the likely cause? How hard is it to swap the bearing? Thanks.
