Engine Missing Probleblems 2003 Expy
Old Mar 3, 2007 | 04:45 PM
hawk37's Avatar
hawk37
When the temperature changes a lot during damp weather creating foggy conditions. Engine misses badly and I get a diagnostic code which states No. 5 cylinder miss. This has occurred several times. I had the spark plugs changed but the condition has occurred again. After the engine has warmed and the car has left to sit awhile the problem will go away. Any ideas
Old Mar 3, 2007 | 05:58 PM
FTE Herman's Avatar
FTE Herman
Welcome hawk! More than likely, you are getting residual moisture in the COP on that cylinder.
Old Mar 3, 2007 | 08:02 PM
hawk37's Avatar
hawk37
Thank you for your response, I assume I can replace the COP on that cylinder only.
Old Mar 3, 2007 | 11:22 PM
yardbird's Avatar
yardbird
I have the exact same problem with the same cylinder, except the weather don't have to be damp.
I have changed the spark plug, COP, and injector, and not one bit of difference. If you find your problem please let me know.
2003 4.6 Expy.
Old Mar 5, 2007 | 06:12 PM
hawk37's Avatar
hawk37
That news is discouraging. Since the problem only occurs spradically it might take some time to resolve. I have sprayed all the wires with a silicon spray and it has reduced the occurence to only once since. I was going to try and concentrate the spray to only the No. 5 cylinder. I will let you know if I get it solved.
I hope someone out there has had the same problem and can give us more insight.
