No CD player power
Old Mar 3, 2007 | 02:14 PM
7600rem's Avatar
7600rem
No CD player power
I have a 04 FX4 and have no cd player no raidio no clock nothing no power at all. I pulled fuses everything good . Any ideas to fix or find problem would be great.
Old Mar 3, 2007 | 03:16 PM
pukemon's Avatar
pukemon
i would double the check the fuses. there might be more than one fuse that relates to this area and check your wiring if possible. or maybe it's time to get a new head unit.
Old Mar 3, 2007 | 03:17 PM
screwy's Avatar
screwy
Do your power windows work?
Welcome to FTE.
Old Mar 3, 2007 | 04:10 PM
7600rem's Avatar
7600rem
power windows work and all lights and gadges work. thanks for the replys
Old Mar 3, 2007 | 06:19 PM
7600rem's Avatar
7600rem
Cheked all possible fuses and still nothing.
Old Mar 3, 2007 | 06:41 PM
pukemon's Avatar
pukemon
could be the head unit. if you know how to wire up a head unit and happen to have one laying around that works, you could try that.
Old Mar 3, 2007 | 08:10 PM
FTE Trigger's Avatar
FTE Trigger
pukemon, has a good suggestion... but instead of putting in a new H/U I would use a meter on the harness to see if you have power there.
Then there is your accessory delay... then there is the Central Junct. box. and the GEM module... So it could be a dead output somewhere through there...
Old Mar 3, 2007 | 09:13 PM
screwy's Avatar
screwy
Well the fact the windows are working means your problem is after the accessory relay, I’m going to look at some wiring diagrams.
Old Mar 3, 2007 | 09:28 PM
FTE Trigger
I forgot to ask before.... but is this the Factory radio or a aftermarket unit?
Also I have spotted some grounding points in the right front (pssngr) footwell as well as noticing the CJB, outputs...
Last edited by FTE Trigger; Mar 3, 2007 at 09:30 PM. Reason: forgot the grounding point addition..
Old Mar 4, 2007 | 06:51 AM
7600rem's Avatar
7600rem
This is a Ford factory unit. I used a test light on the harnes and the is no power so it seems to be in the wires some place
