View Poll Results: Whick would you do first
Tranny Filter
31.03%
Boot Kit
17.24%
Line-X
51.72%
Voters: 29. You may not vote on this poll
Whats Next?
Old Mar 3, 2007 | 09:43 AM
Uzumati's Avatar
Uzumati
Whats Next?
Tranny Filter - Dieselsite Tranny Filter with flush valve
IC Boot Kit - Dont really need them yet but the new ones from Dieselsite look good
Line-X - Pickup bed and wanting to spray from the body molding down
Which one first, I really hate this part of PMS - having to pick only one.
Old Mar 3, 2007 | 09:54 AM
cangim's Avatar
cangim
I am for tranny filter, even if you scratch up the bed now, it is still going to look awesome whenever you do the line-X.
Old Mar 3, 2007 | 11:14 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I chose the boot kit, because i have heard that Brian at BTS has found out that the transmission runs 10-20* hotter with one, and he prefers to not use it.
Old Mar 3, 2007 | 11:25 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I choose the boot kit too. I will ordering a set from DieselSite after I buy Mama all new furniture for the lving room. She said so.
Old Mar 3, 2007 | 11:33 AM
hosemandc's Avatar
hosemandc
I have to say spray in liner. If I dont my truck is going to rust away. I am going to do the bed and bottom quarter of the truck as soon as I figure out what color would go the best with my red truck.
Old Mar 3, 2007 | 01:47 PM
bdrummonds's Avatar
bdrummonds
Line X/ Rhino/ whoever if you haul ANYTHING in the bed you know it slides around. Not with the spray in liner, it stays put. When my truck was new I had a double shot of rhino put in( its 1/4 to 3/8 inch thick) and after 7 years I only have a couple of scars in it.
Old Mar 3, 2007 | 05:48 PM
shenders99's Avatar
shenders99
I would say the bedliner. For anyone that hates calling it by brand names it is a polyurea/urethane hybrid.
I am biased though, being in the plural component application and material manufacturing industry.
Old Mar 3, 2007 | 05:56 PM
John311t's Avatar
John311t
I would say spray in bedliner.
Old Mar 3, 2007 | 06:04 PM
ron's power stroke's Avatar
ron's power stroke
brian told me not to run a second trans filter as well..it lowers the line pressure and makes it run a little hotter..i like the bed liner idea..i want to do mine in side and under the bed..i also want to do under the cab from the frame rail out to the rockers...we get alot of road salt here
Old Mar 3, 2007 | 07:08 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
I'd go with the boot kit, it has served me well. As far as spray-in liner material, Rhino gets my money.
Old Mar 3, 2007 | 07:33 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Well, I have the rhino lining, I would like some wheel well and frame/undercarriage done so I would vote lining.
Old Mar 3, 2007 | 08:39 PM
Wieckster's Avatar
Wieckster
I have the line-x lining and I wouldnt own another truck without it
Old Mar 3, 2007 | 09:01 PM
TwelveAlpha's Avatar
TwelveAlpha
boots. Aren't we close to your tranny needin replaced anyway, or did I miss that?
Old Mar 3, 2007 | 09:12 PM
Uzumati's Avatar
Uzumati
Nope mine is fine for now (wood knocked on) that is Pocket wishing for his tranny to go so he gets a BTS.
Old Mar 4, 2007 | 11:20 AM
jtharvey's Avatar
jtharvey
I say bedliner. The previous owner has a Rhino liner sprayed in, and I'm glad I have it. No worries about rust, scratches, or damage to the bed. I don't know how long he had it in there, but in the 3 years I've had the truck it's holding up fine.
Oh, and guess who else is not running an external tranny filter anymore (that'd be me). Brian suggested I remove it as well, but he's also modifying the pump to flow a lot more fluid. So, the filter might be a restriction with his higher flow pump, but would probably be ok with a stock pump. But, since the trans his his product and he'll be repairing it if it were to ever fail, I followed his advice and removed mine.
I haven't given up on the idea of an external trans filter though. I'm thinking some type of bypass filter would work, just as long as all the fluid doesn't have to go through it. Tap into a tranny line for a feed and find a good place to return it. Just an idea for now though.
