fuel tank
Old Mar 2, 2007 | 06:20 PM
Farmall05's Avatar
Farmall05
fuel tank
I am working on a 90 f 150 with duel tanks, I was wanting to know if any one knows if the 32 gallon tank out of a bronco would fit in place of the rear 19 gallon tank. I know if it would work I would need new tank straps and all but I cant find dementions for the 32 gallon tank to see if it would fit
Old Mar 2, 2007 | 08:39 PM
95X15's Avatar
95X15
I do know it gets extra capacity from added depth so the spare couldn't go back with any of the bracketry without hanging way down. I would guess that the frame spacing might be close to a 150 but sure wouldn't bet anything on it.
If you can find a Bronco to measure, try getting some dimensions to compare to yours.
Old Mar 2, 2007 | 09:25 PM
Redcat Diesel's Avatar
Redcat Diesel
A friend of mine has a Bronco tank in his 87 F150. He just used the straps from the Bronco and it bolted right in.
The spare tire hanger will not work with the Bronco tank.My buddy has his mounted in the bed.Hope this helps.
Old Mar 3, 2007 | 07:27 AM
Farmall05's Avatar
Farmall05
that helps alot, It dosnt have a spare so I dont have to wory about that, Thanks for the help
Old Mar 3, 2007 | 09:11 AM
lostin90s's Avatar
lostin90s
I had to add a piece of angle because tank wasn't as wide/long but used bronco skid plat/straps to hold in. I love the extra capacity but haveing the spare in bed sucks. Goood luck
