Can't get started
Old Mar 2, 2007 | 09:16 AM
5.8 Ford's Avatar
5.8 Ford
Can't get started
I have a 1983 F-250 with a 351W and everytime i try to start it ,the spark plugs flood out. When i replace the plugs it wants to start but doesn't. The plugs end up getting flooded. I've replaced the distributor cap and rotor still nothing.
Please help I've been working on it for almost 3 weeks.
Old Mar 2, 2007 | 01:37 PM
ubereal2's Avatar
ubereal2
If you've checked for a good spark, and have one, I'd do a compression check on all cylnders next.
Old Mar 2, 2007 | 01:41 PM
Franklin2's Avatar
Franklin2
Take the aircleaner off after you try to start it, and look down the carb throat(you may have to pull the choke door out of the way). If you have fuel dripping down in the throat of the carb, then I suspect you have a piece of dirt stuck in the float needle of the carb, hanging it open. The fuel level goes way too high and just pours into the engine.
Old Mar 2, 2007 | 02:12 PM
5.8 Ford's Avatar
5.8 Ford
Ok, I've got the flooding problem fixed. Now Its backfiring through the carb and blowing flames up through it. It runs for about 5 sec and quits.
Old Mar 2, 2007 | 03:43 PM
Franklin2's Avatar
Franklin2
Now it sounds like it's lean and running out of fuel. Did you adjust something too far?
Old Mar 2, 2007 | 05:11 PM
Skoiv's Avatar
Skoiv
Could be the timing as well. Twist that distributor until you get it started. It would be easier if there was two people. Someone can turn the dist while you crank it over.
