1978 - 1996 Big Bronco
floor shifter
Old Mar 1, 2007 | 09:12 PM
T.Barton's Avatar
T.Barton
Lightbulb floor shifter
I have a 79 bronco that I would like to put a tilt collum in it and I also like to put a floor shift in it to I was wandering if any body out there might have done this and if so do you like it and were did you find the parts from
Old Mar 1, 2007 | 10:07 PM
Tdvjensen's Avatar
Tdvjensen
B&M makes a series of nice shifters. A friend of mine has one in his bronco and i am looking at one for my other bronco. They are a cable style shifter that comes with brackets for the c6 when ordered that way, and I think the cable has to be measured depending on where you want to install it. My friend has his mounted on a base that he built to get it up to about level with the base of the seat. It works very well too. As for the tilt column, I would check out Jeff's bronco graveyard as they would most likely have a stock tilt column assembly for you to purchase.
Old Mar 7, 2007 | 10:27 PM
led129's Avatar
led129
sorry posted in wrong thread.
