ac bad smell
Old Mar 1, 2007 | 07:42 PM
hotrod351's Avatar
hotrod351
ac bad smell
i get that awful smell from my ac in the summer. wondered what products any of you have used to fix this problem with success.
Old Mar 4, 2007 | 03:13 AM
bustech81's Avatar
bustech81
I see this problem alot. What has happened is that your evap coil will condensate a little bit when you run it. There is a drain in the bottom of your heater box that allows this water to drain onto the ground. this drain consits of a piece of plastic hose that has a duckbill on the end of it. check to make sure that it is clear of debris. To get rid of the smell, mix 50/50 clorox and water and pour it down the cowl vent. then flush with clean water. good luck.
Old Mar 4, 2007 | 11:04 AM
hotrod351's Avatar
hotrod351
i tried looking under the truck for the drain tube but didn't find it. any idea where it is. i have a 1990 4X4.
Old Mar 4, 2007 | 02:39 PM
Ultramagdan's Avatar
Ultramagdan
Should be on the passenger side and close to the firewall.
Old Mar 5, 2007 | 10:09 PM
hotrod351's Avatar
hotrod351
ill look tomorrow for it. im figuring it should be a hose of some type hanging down.
Old Mar 6, 2007 | 07:58 AM
projectSHO89's Avatar
projectSHO89
There should be a hose. However, in some applications, it's only a plastic nipple that goes through the base of the firewall.
Look directly below where the evaporator lines are connected.
Steve
BigBus
Jul 9, 2013 09:44 PM
DGMFORD
Nov 21, 2008 12:03 PM
cbrown
Jul 18, 2005 06:15 PM
rockgt302
16
Jul 7, 2005 12:15 AM
millersnva1
Dec 21, 2001 07:59 PM
