tire size?
Old Mar 1, 2007 | 06:58 PM
OzarksFord's Avatar
OzarksFord
tire size?
My 1983 F150 originally came with 215/75/15 tires. I am sure that the rims are original. It currently has 225/75/15 tires. Can I put 235/75/15 tires on these rims? Will it affect the speedometer?
Old Mar 1, 2007 | 09:34 PM
surewhynot's Avatar
surewhynot
Yes you can put those tires on the rims and yes it will affect the speedo. Somewhere on this site there are calculators to show you how far off it will be i believe.
Old Mar 1, 2007 | 09:57 PM
bgriffin09's Avatar
bgriffin09
as long as you keep the same sidewall ratio and rim size. (ie 75/15) it will not effect the speedo. the 235 is just the width.
Old Mar 1, 2007 | 10:01 PM
surewhynot's Avatar
surewhynot
the 75 is the aspect ratio. It is 75% of the width. So as the tire gets wider it also gets taller.
Old Mar 2, 2007 | 12:17 AM
bgriffin09's Avatar
bgriffin09
you're absolutely right...my mistake.
Old Mar 2, 2007 | 10:13 AM
OzarksFord's Avatar
OzarksFord
I am guessing that a taller tire, you will actually be going slower than what the speedo reads. As long as I don't have to worry about speeding, it doesn't matter. So, does a taller tire mean you are going slower or faster than what the speedo is reading?
Old Mar 2, 2007 | 10:54 AM
surewhynot's Avatar
surewhynot
Just the opposite. A taller tire means you will be going faster than your speedo says.
