Wicked wheel. Done it Tuesday and boy am I satisfied. Got rid of my surging problems and the sound is awesome under the slightest load. Over all not a bad job at all, just a little hard to get to some points such as the clamp on the downtube and the wastegate actuator was a bit of a pain.
This has to stop soon.....I want more and more mods now!!!!!
"PMS (masculine version): Once a patient has been verified to contract this insidious form of malignancy, it has been proven that there is no cure. The process of diagnosis can be a rather drawn out process due to the subtle imposition of this disorder's effects on the patient. The diagnosis, though, once confirmed, is certain! Although a cure is not yet known, through the regular encouragements of significant others in the patients life (such as spouse, parent, etc.), the impact of this disorder can sometimes be controlled to varying degrees, depending upon the level obstinacy and potential consequences imposed by either party involved. The symptoms of this disorder, as with many other auto-immune disorders, causes the patient to take otherwise normal information regarding the object of their newfound passion (usually, a truck) and re-interpret that information into some twisted reason for further investment. It almost seems that no one is truly resistant to this disorder, and its long term effects have been known to result in a variety of situations that can have permanent impact on the patient's livelihood, relationships with others, and overall lifestyle. The best treatment found to-date is the most difficult for the patient to survive, since it requires getting rid of the forestated object of their passion (usually, a truck). Even with this severe form of treatment, residual problems exist in the patients mental capacities, and even these patients typically end up returning to their prior condition by eventually justifying the re-acquisition of another object similar (or newer and better) to that when the dirsorder was first discovered."
how does it compare to the turbo whistle on the 6.0 kwik?
That's comparing apples to oranges. It would be nice to have a 6.0 turbine on my 7.3 but it would require too much redesign of the engine management system.
