Black Cam Lobes?
Old Feb 28, 2007 | 09:47 PM
lewislynn's Avatar
lewislynn
Black Cam Lobes?
I picked up my new cam today. I opened the box when I got home and all the cam lobes ARE BLACK, not polished WTF?
I guess I'll call the shop in the A.M. to find out what's up with that
Anybody else have that happen?
Old Feb 28, 2007 | 11:28 PM
know_fear's Avatar
know_fear
Don't bother. It's a surface treatment (Parkerizing I think) that holds the oil and helps to break in the lobe to lifter mating surfaces. All new cams have it. It will wear down to a nice polished appearance as you do your initial run in. Make sure you use a high zinc content oil or use a zinc additive.
Old Feb 28, 2007 | 11:39 PM
lewislynn's Avatar
lewislynn
Thanks, I was hoping it was something like that.
What oil would you recommend?
Old Feb 28, 2007 | 11:49 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check the oil and lube forum but I believe it is recommended to use Diesel engine oil. The cam manufacturers instructions should mention it also.
BTW, It IS called Parkerizing.
http://www.wordwebonline.com/search....&w=Parkerizing
Old Mar 1, 2007 | 09:37 AM
monsterbaby's Avatar
monsterbaby
Eric is correct I use rottella 15w-40 oil for initial break in and also be sure to put some cam break in lube on each lobe before installing. also you can run other oils but put in a can of GM EOS that will add the zinc too.
Old Mar 1, 2007 | 10:24 AM
baddad457's Avatar
baddad457
The Black is a parkerized finish meant to let the cam lobe spin the lifter in it's bore. No spin = sure death in a few minutes run time for both cam and lifter. So too much lube is as bad as not enough.
Jake Sanchez
1997 - 2003 F150
Nov 24, 2016 01:27 PM
Mudsport96
Jul 10, 2016 10:33 AM
AndysFords
Aug 25, 2010 10:37 PM
Packard V8
Oct 9, 2009 10:42 AM
hiball3985
Jun 6, 2005 07:41 PM
