1978 - 1996 Big Bronco
loud whine - NEED HELP!
Old Sep 15, 2002 | 09:47 AM
cangiman's Avatar
cangiman
OK here is my problem - I started my truck this morning, drove about a mile,stoped at a light, and started getting a loud whine fome the engine. (LOUD almost like a whistle). The sound stays until about 30 mph then goes away. As soon as I let off the gas, it comes right back. Also whines in park.
It's an 88 xlt 302 with 115K. I recently had Starter, soleniod, battery, and alternator replaced.
Any ideas?
Old Sep 15, 2002 | 09:51 AM
msautry's Avatar
msautry
Sounds a lot like you've got some belt slippage. You can check this by taking a candle and rubbing the wax on the underside of the belt and starting the engine. If it doesn't make any noise, you've found it. Replace the belt. You can also check it with a piece of soap.
Hope this helps
Old Sep 15, 2002 | 10:10 AM
cangiman's Avatar
cangiman
I just tried that with no luch. it seems like the whine last for about 2 seconds after I turn off the engine.
Old Sep 15, 2002 | 02:06 PM
cangiman's Avatar
cangiman
Some more info - I seems to happen when the truck gets warmed up.
thanks
Old Sep 15, 2002 | 03:40 PM
bronco351's Avatar
bronco351
The belt is loose. I suggest you look at your owners manual and see where to tighten it. That should fix your problem!!
Old Sep 15, 2002 | 04:01 PM
bronco351's Avatar
bronco351
