360 starting problem
Old Feb 27, 2007 | 09:14 PM
spit's Avatar
spit
i read the 360 thread, my problem is different- my ford 360 'will' start but doesnt keep running!- i have to try maybe 30 times or more!- only thing is when its started it runs GREAT- i took it to a repair shop tonight- and must of shut it off and started it a dozen times without any problem!- so i get it home- shut it off- then it doesnt want to start it again- i mean it 'wants to start' the engine 'kicks in' for lack of better words, but then immediatly shuts down- i got a manual fuel pump on it- it works fine when the trucks running-- is that the problem? or a carbuearator problem?- thx- john (maybe something else?)
Old Feb 28, 2007 | 01:14 AM
Torque1st's Avatar
Torque1st
Posting Legend
Unfortunately you don't say what year your truck is which makes for a real guessing game. Possibly a bad ignition switch, ignition pickup module or points wiring, or bad ignition module or condenser.
Old Feb 28, 2007 | 06:54 AM
117wb 4sp.'s Avatar
117wb 4sp.
i had them start on start but not on run. what i mean is it will start why you turn it over then as soon as you let off the key it dies. was the brian box.one other way is when it ack up run a hot wire from battery to coil and see if it runns then but don,t leave it on long only to check. alan
Old Feb 28, 2007 | 07:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
His profile says 1978, and you know what module that year uses...the dreaded RED one.
There's an off chance the ignition module could be a BLUE one, but those were pretty much trouble free.
DuraSpark in 1977/78 = NeverStart
Old Feb 28, 2007 | 07:45 AM
76supercab2's Avatar
76supercab2
If it really is a 360 and really a 78, then it's a frankentruck of some sort. 360 was no longer used after 76.
The description sounds like it could be a wire broken inside the insulation. Very difficult to diagnose.
Old Feb 28, 2007 | 07:48 AM
NumberDummy
Could have confused 360 with F350...just never know today...or yesterday for that matter.
Old Feb 28, 2007 | 08:01 AM
spit's Avatar
spit
the trucks a 78-- but the engine is from a 75 or 76- LOL (sorry bout that) by the replies then- i seem to be ok with fuel pump since its works well when the trucksd keeps running after it 'stays' started-- im gonna print all the replies and show em to mechanic friend since i dont understand this electronic stuff- john
Old Feb 28, 2007 | 09:47 AM
spit's Avatar
spit
ok guys- i found out what it is!!- so if anyone has this 'problem'- i found out by accident- its the ignition!-- everything works good it seemed- but the 'spring' or something didnt fully release it- when i start it, then just tap it couterclockwise- the engine kicks in!- john
Old Feb 28, 2007 | 12:42 PM
Mil1ion's Avatar
Mil1ion
The Ignition ?
You need to be more specific.
The Ignition consists of all these parts.
also, 78's don't have Brain Boxes (aka Computers) they have Ingition modules as shown
in the illustration above .
"Terminology is Everything" on a tech site
Old Feb 28, 2007 | 07:17 PM
117wb 4sp.'s Avatar
117wb 4sp.
ya i,ve always called the IM a brain boxs ,thats funny abount the blue box thats the one i,ve alway went out. he talking abount the key switch i bet that just worn out. alan
Old Feb 28, 2007 | 09:01 PM
spit's Avatar
spit
yea, the key switch- sorry about the tech wording, but im a home mechanic at best- john
