Injector results
Old Feb 27, 2007 | 06:26 PM
whatsparkplug's Avatar
whatsparkplug
Injector results
Been driving the truck for three days now after installing new injectors and have noticed thr truck is actually running better than it ever has since I bought it about 7 months ago. Got a nagging dang air leak that I'm trying to find now that will make it crank and then die and will not start back up. First thing this morning had to bleed the shrader and crack injector to get her going. Tinkered a little this evening and found the fuel line coming from the filter had a bad clamp and I was able to spin it and pull it off by hand real easy. Hope that maybe that's my air source. Just my evening redneck diary for yall to read.
Old Feb 28, 2007 | 07:41 AM
bigbubba87's Avatar
bigbubba87
look at the rubber fuel hose between the fuel pump and where it goes into the solid plastic and runs down the frame mine had a pinhole in that hose i tore all the lines off injectors lines injector pump and it was a little 6" piece or hose
