"Jittery" Speedometer Needle
Old Feb 27, 2007 | 12:12 PM
Nightrain's Avatar
Nightrain
Just picked up an '85 F-150 4.9L/4-speed from the local tote'the'note for $400 cash.
Darn 'ol truck runs like a top, ain't beat up or nothing, and doesn't have any rust problems at all (except for some MINOR surface rust beginning, which will be taken care of later).
Anywho, I noticed on the test drive that the speedometer didn't work. Then, on my way home, it starts picking up and jumping around on 15mph when I think I'm doing 30-35mph.
Then, when I'm up to 55-60mph, it jumps around on 45mph.
I bought a "universal" speedometer cable kit before it ever showed signs of even working at all, but now I'm not sure where to begin.
I thought of starting by loosening the bolt that houses the speedo' gear in the transmission and see if there are any loose connections, or what have you, at that point.
I had an '85 F-250 6.9L/C6 that did the same thing, but never dove into it to figure out the problem.
Any insight would be great!
Nightrain
Old Feb 27, 2007 | 12:42 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The cable is probably frayed and worn out. Shot etc...
Replacing it is probably the best course of action. Remove the old cable to check for damage etc.. It seperates for the plastic housing you will have to remove the cluster and speedometer cable gear from the cable (held on with a clip) at the other end at the tranny. Should pull right out of it's housing from the inside of the cab.
Make sure you lubricate the new cable with either speedometer cable lubricant Ford Part Number: D2AZ-19581-A / specification ESF-M1C160-A. Or white lithium grease will also work well.
Lubricate the cable every year or so, or any time a slight needle hop is detected.
hope this helps
Old Feb 27, 2007 | 01:23 PM
Nightrain's Avatar
Nightrain
Thanks for the advice, bud.
I'll pull everything out tomorrow and get 'er fixed (hopefully).
Thanks again!
Nightrain
Old Feb 27, 2007 | 02:12 PM
Franklin2's Avatar
Franklin2
You can pull the cable loose at the tranny end, and twirl it with your fingers and see how freely it turns. You can also do this while someone is watching the needle in the cab.
If you put a new cable on, and it still does it, then the old cable may have ruined the plastic gear that goes up in the tranny housing.
Old Feb 27, 2007 | 07:06 PM
82F1507.5's Avatar
82F1507.5
Even if the plastic speedometer gear is shot, inside where the cable goes or outside on the gear teeth, Ford still stocks them. You will need engine size, wheel size, gear ratio, tire size, type transmission when ordering from Ford.
Old Feb 28, 2007 | 08:24 AM
Nightrain's Avatar
Nightrain
Thanks, ya'll.
I was thinking at first that something had come loose, but when it started working on the way home, I didn't know where to start.
I am going to replace the cable with the kit I bought today and see what happens.
But, if it still does it with the new cable, replace the plastic gear in the trans, right?
Thanks again!
Nightrain
Old Feb 28, 2007 | 02:31 PM
Nightrain's Avatar
Nightrain
Welp, I seem to be stumped again...
I pulled the cable and drive gear out of the transmission and spun it with my fingers while the wifey-to-be watched the needle. It moves. The cable also spins freely.
But, when inserted back into the transmission and given a little test drive down the road, I still have nothing 'till about 55mph or so, where the needle begins to jump between 35-45mph.
I pulled the cluster out before that, and the cable has a firm connection with the speedometer itself.
Also, the gear doesn't look to be worn out. I still haven't replaced the cable, but plan on doing so once I get some sleep. Whether or not it needs it at this point is unclear, but it is "fix-it-before-it-fails" maintenance.
Thanks for all of the help, ya'll...
Nightrain
Old Feb 28, 2007 | 02:55 PM
81-F-150-Explorer
It could be the speedometer head itself too.
Does the odometer work even when the needle isnt moving?
Edit: Just reread your post.
It seems to be the plastic gear inside the transmission is probably at fault.
There are two gears one at the end of the cable that sticks into the transmission, and the other gear this one mates to inside the transmission itself.
The gear inside the tranny is not easy to replace either.
Old Mar 1, 2007 | 08:40 AM
Nightrain's Avatar
Nightrain
I haven't paid any attention to the odometer, but I'll check it and see next time I'm out and about.
When I check it, I'll let ya'll know what prevails.
Thanks again.
Nightrain
Old Mar 1, 2007 | 01:05 PM
84GRANNYFEAR's Avatar
84GRANNYFEAR
Speedometer Cable............................................. 5.00
This is the price I paid for the used cable from Crazy Rays in Jessup Maryland. Did the replacement in a bout 45 mins to an hour (not in a rush).
http://www.crazyraysautoparts.com/price.htm
84 Ford F-150 4.9L carby, w manual granny gear. All stock but I do have the OEM clock...woohoo!
Old Mar 1, 2007 | 01:54 PM
Piffery1's Avatar
Piffery1
Clean and lube the cable and housing (both sections if you have speed control). I use lithium or molybdenum disulfide based lube or white marine grease. Getting all the old hardened grease out seems to make a big difference.
Old Mar 2, 2007 | 04:31 PM
Nightrain's Avatar
Nightrain
Oh, I will definitely try the cable first.
I'm just hoping that fixes the problem...
Thanks again, ya'll.
Nightrain
Old Mar 4, 2007 | 09:27 AM
Sport45's Avatar
Sport45
Do you have cruise control? If so, you may have 2 cores in your speedometer cable. Separate it at the CC pickup coil to check the short length that runs to the speedometer head.
The driven gear gear will probably look like one of these:
They can break, strip, or were sometimes trimmed by previous owners in order to drive without running up the odometer. Replacements aren't hard to find and they are color-coded for tooth count.
Speedometer World
Old Mar 4, 2007 | 12:01 PM
Nightrain's Avatar
Nightrain
Mine is white. Looks like the tooths are in good shape, though. (Don't make fun of me; I'm from the South). :-x22
I'm going to start with the cable and move on from there, as needed.
BTW, the 'ol rig don't have cruise control. She's standard and stripped-down all the way...
Thanks again.
Nightrain
Old Apr 22, 2007 | 03:13 PM
f100guy's Avatar
f100guy
nobody said anything about the drive gear inside the tranny itself. it could be stripped.
