Sponsored by: Auxito
Starting Problem
Old Feb 27, 2007 | 09:01 AM
billn's Avatar
billn
Starting Problem
I have a 97 F150 4.6 automatic. When you try to start the engine the starter grinds like it's not engaging the flywheel unless you pull back on the shifter then it fires right up. It had issues with the shift tube, the tube was broken, the screws at the end of the tube were loose, and the bushings were wore out. I fixed these things and that took the play out of the shifter, but I still have the starting problem. Any ideas?
Old Feb 27, 2007 | 12:56 PM
Bluegrass 7's Avatar
Bluegrass 7
Trans shift selector. Adjustment or fault.
